AC/Heater knob won't stay down!
Old Oct 24, 2005 | 05:29 PM
Lancestuh817's Avatar
Ok people I have searched and can't find out how to get the AC/Heater knob to go al the way down! It's getting cold in Texas and the knob will not go all the way down. I do have a HU! It's like when I try to switch to the heater when you try to make it go it hot, it shoots back up to the middle their isn't a rock or anything that I saw and the vaccum also! What could be the problem?
Old Oct 25, 2005 | 03:30 AM
brentg07's Avatar
I think I remember somebody posting on here once that the dealership replaced their ac control knob because there was a technical bulletin about it being hard to turn. Mine is very hard to turn sometimes, especially when you hit the point where your turning on the heat. Check with the dealership and see what they say.
Old Oct 25, 2005 | 05:52 AM
twardnw's Avatar
^yep, there's a TSB out for it, dealership should fix it free of charge
Old Oct 25, 2005 | 12:30 PM
sykou's Avatar
Mines is hard to turn where the cold turns to the hot but they didn't fix it because it still worked. If yours is stuck and doesn't move then they should replace it.
Old Oct 25, 2005 | 12:38 PM
Dookie's Avatar
It's actually the entire heater box under the dash that is defective. There is a TSB out for this. They replaced mine because the TSB states that if the knob is hard to rotate or is binding, replace the heater box. It's not a quick job, as they have to deplete the A/C and all that stuff.
8AVETTE
Mar 24, 2014 08:35 PM
MagnumVP
Apr 8, 2012 03:12 PM
detroit pistins
17
Nov 7, 2011 02:53 AM
stareandwonder
Lancer Troubleshooting
18
Oct 6, 2009 12:33 PM
mitsuorder
Dec 24, 2006 03:25 PM
