If I Get Zapped One More Time . . . !!!
ok this is really starting to **** me off. EVERY time i get out of the car as soon as i touch the door with my foot on the ground my ha d damn near gets blown off. Im getting HUGE static shocks off my car. Does anyone know how to stop this ? Is anyone else getting zapped like this ?
if it bothers you that bad get a grounding strap....or anti static spray..... http://www.topoftheline.com/anspray.html
Part of it is the amount of actual rubber they put in your tires. Honda had a recall (Tech Bulletin) because there customers were getting shocked all the time. If you just changed tires it may have something to do with it especially if they are long tread length (high wear rating) tires. Other than that, ground out on your car as you get out as twardOZRally.
i always freakin get zapped too! i let my jacket sleeve fall down over my hand and then use that as a buffre when i grab the door frame-kind of like a hotmit. the other thiong is....are you grabing the outside door handle to shut the door? It is plastic and may not shock you. I get shocked when i grab the door framer to shut the door!
im gonna try a few things, ive got a grounding kit coming for the engine bay, im also going to try a grounding strap to the ground (although i hate **** dragging on the ground from my ride) and im going to see if theres a better way to ground the seats out so your butt doesnt build as much static!!
