Help!
Old Dec 16, 2005 | 08:36 PM
drew02ES's Avatar
Help!
i just installed rrm header, high flow cat, and greddy evoii catback
i drove around for a while, went home, parked, when i turned my car off the electricity went NUTS, everything was flickering, it was making a clicking sound
now my car wont start
Old Dec 16, 2005 | 08:37 PM
sykou's Avatar
sounds like you had a short. Try checking the amp fuse by the battery. Prolly fried it. Make sure your wires arent rubbing against anything that could cut them...
Old Dec 16, 2005 | 08:40 PM
03RallyLancer's Avatar
i have no idea... cel?... where the clicking coming from?
ambystom01's Avatar
What he said, maybe you got oil/water on some of the wires when you did the install.
drew02ES's Avatar
yeah CEL has been on since i first started the car after installing the header
going to take some pic and try to locate the clicking
everything kind of flickers and makes noise
Old Dec 16, 2005 | 09:00 PM
drew02ES's Avatar
the fuse looks okay
i unhooked my battery before i posted this, i went down and re hooked it up, when i first turned they key everything was fine, but my car still wouldn't start ( this time it as least "tried" ) then i tried my system, it came on, it his really... laggy? and then faded out, sounded like ****, and died
Old Dec 16, 2005 | 09:01 PM
drew02ES's Avatar
Old Dec 16, 2005 | 09:03 PM
drew02ES's Avatar
i'm suppost to pick someone up in 2 hours anyone have any ideas?
did my battery just die?
Old Dec 16, 2005 | 09:05 PM
drew02ES's Avatar
when my door is open and the dome light is on, if i tap my brake it makes the light flash as i hit the brake WTF?
Old Dec 16, 2005 | 09:11 PM
drew02ES's Avatar
anyone?
Old Dec 16, 2005 | 09:18 PM
Z_Lancer_Man's Avatar
That picture above is the fuse for your stereo amp power wire. If you have power than the 100 A fuse on the battery is good. Let's work backwards. Installing the exhaust piping shouldn't have come close to any wiring, so I highly doubt thats the reason. However, the header requires the moving of the O2 sensor. Check the wiring for the o2 sensor. Has it melted? Is it caught on anything? Take a pic of it if you aren't sure.
Old Dec 16, 2005 | 09:39 PM
drew02ES's Avatar
Old Dec 16, 2005 | 09:40 PM
drew02ES's Avatar
hanahawaiian's Avatar
Recheck! make sure Wires not touch Header, Downpipe and Catback... so so Check out again and make sure O2 senor good... and start again.. maybe Shop fu*ked up ur car?
Old Dec 16, 2005 | 09:42 PM
drew02ES's Avatar
i have no lift no jacks, no nothing! **** i am so pissed off
