Car Shaking
Old Mar 24, 2003 | 08:13 AM
SpeshalK's Avatar
Car Shaking
Lately whenever Im going between 45 and 50mph's my car starts to shake more then it does while driving at any other speed...I have an automatic, i dont know if that makes a difference, but does anyone have an idea of what it could be....
Old Mar 24, 2003 | 08:24 AM
Crzylizard's Avatar
It could be one of two things.
1. Your tires are out of balance.
2. Your tires are out of alignment.
dont let it go too long, itll cause abnormal wear. Take it to a shop and have then re-balance and check your alignment
Old Mar 24, 2003 | 08:54 AM
neilschelly's Avatar
Couldn't have said it better myself...
-N
Old Mar 26, 2003 | 04:58 PM
sdhotwn's Avatar
Most likely your wheels... (bent rim.. out of alignment... yada yada yada...)
BUT....
A cracked spark plug or a loose spark plug wire will also cause what will feel like a shudder. You can usually check that by seeing how the engine responds in the middle of that shaking... play with the gas pedal... put it in neutral etc... and see if it makes a change... if it does... replace the plugs... after that think of something else
chopzilla
Jul 7, 2019 10:09 PM
Redline-Z
May 4, 2016 01:43 PM
princess33
Sep 14, 2014 08:08 AM
LanEvo9MR
Nov 1, 2009 08:44 AM
LancerEVOmann
10
Nov 10, 2004 10:15 AM
