Breaking at High Speeds
Old Mar 26, 2003 | 11:10 AM
chriscoker's Avatar
Question Breaking at High Speeds
I know this is going to sound stupid but I have a 02 Oz Lancer and lets say im hittin like 80-90 Mph and im in say 5th Gear and am looking to break, and I drop it into 4th gear and let off the clutch to slow down and start to press the breaks, well when I do: do that the car kinda shakes and I have a vibration in the stearing wheel. Do I need to get some new Better breaks (cause I drive this fast always)?anyone?
Old Mar 26, 2003 | 11:13 AM
Crzylizard's Avatar
you may want to get your rotors turned....
only logical thing to me
Old Mar 26, 2003 | 11:16 AM
chriscoker's Avatar
This car is brand new tho...only about 14000 miles on it should I really need to get rotars rotated already?
Old Mar 26, 2003 | 11:18 AM
Crzylizard's Avatar
its a possiblity, really depends on how hard you are on your brakes.
Take your wheel off and check your rotors for damage or anyhting that seems out fo the ordinary to you.
It could be something else, but the rotors would be the most logical thing to me
Old Mar 26, 2003 | 11:45 AM
neilschelly's Avatar
I'd guess the rotors too, but I doubt you'd see it if they were slightly warped and it wouldn't take much to introduce vibrating.
But it probably isn't the rotors at all if this only happens when you are compression braking. If it only happens when you use the brake pedal, check the rotors. Otherwise, it could be indicative of something else altogether.
-N
Old Mar 26, 2003 | 11:48 AM
chriscoker's Avatar
Yeah its only when I pressing the breaks while slowing down from high speeds 80,90,100 etc..I mean if im only going like 60 and slowing down its not ****...doesnt vibrate only when going fast.
Old Mar 26, 2003 | 11:58 AM
Alright, if compression braking has nothing to do with it, then check your rotors. I suppose wheel balance issues may be at fault too, but you'd feel them accelerating through the same speeds.
-N
nathantk94
Oct 24, 2016 09:10 AM
Bigboost1320
12
Jun 22, 2015 03:44 AM
longdingydong
24
Dec 12, 2011 06:10 PM
MaxKanisha
Jul 2, 2007 08:45 AM
lancergsrix
16
Dec 1, 2006 01:52 PM
