Odd Problem
Old Feb 9, 2006 | 03:28 PM
yellance's Avatar
Odd Problem
Driving home from class last night and through a service engine soon light.Went to autozone had the code pulled and PO172 system to rich(bank1) i do have the piggy back vr1 so what do you guys think
Old Feb 9, 2006 | 04:59 PM
comatose721's Avatar
pull out your plugs and post pics. they will tell you a lot more than the CEL...otherwise try reflashing the ECU and letting the PB relearn itself. maybe it just got a little surge happy. do you have any mechanical noises, lag, etc after the CEL.
Old Feb 9, 2006 | 05:17 PM
yellance's Avatar
nope already reset the piggy and the funny thing is when the cel comes on nothing happens still the same
Old Feb 9, 2006 | 08:37 PM
start simple. check your plugs, make sure injectors are seated properly and all the sensors are in, PCV valve, etc. but start at your plugs and work from there.....lastly, you'd have to ask Hobie but it MIGHT be a possibility that a sensor/clip on one of your injectors could have gone bad so the ECU is just dumping crazy amounts of fuel. i heard of that in a civic once.
Old Feb 9, 2006 | 10:08 PM
yellance's Avatar
ok checked the plugs 3 of the 4 are black as night so might be the problem i will find out this weekend
Old Feb 10, 2006 | 06:45 AM
either clean em, regap, reinstall. or just get new ones.
Rado_93
Mar 22, 2016 09:02 AM
bz963
Jul 22, 2010 04:22 PM
APEX1
Aug 18, 2006 11:19 PM
evolved1
Jul 14, 2004 07:05 AM
