Steering Wheel Shakes
Old Apr 4, 2003 | 04:07 AM
Charles1's Avatar
OK well my steering wheel shakes alot after i go 55mph or faster dont know why. Which when the wheel shakes my front tires shake. Do i have to get my car alligned or is it serious. I took both of my front tires out and swithched them with the back it helped somewhat but the shaking steel continues. What might it be?
Old Apr 4, 2003 | 04:15 AM
evo_dan's Avatar
You may have lost a wheel weight. I'd say, get your wheels balanced.
Old Apr 4, 2003 | 04:18 AM
Charles1's Avatar
tried it didnt work
Old Apr 4, 2003 | 08:59 AM
neilschelly's Avatar
It's either an alignment or wheel balance issue. If the car pulls to one side, it's alignment. If not, then you got ripped off on that wheel balancing.
-N
Old Apr 4, 2003 | 07:44 PM
Charles1's Avatar
yeah it goes to the side the right side while it shakes alot on the left front tire
Old Apr 5, 2003 | 12:05 AM
You shouldn't be able to tell which tire is shaking. The response in the steering wheel would be indistinguishable. Now if you can see the wheel shaking, then stop driving and get it towed somewhere.
Old Apr 5, 2003 | 12:08 AM
andenbre's Avatar
could be a shifted belt if it moved with the tire
Old Apr 5, 2003 | 12:26 AM
DaTenshi's Avatar
Alignment thats what fixed mine
Old Apr 5, 2003 | 12:33 AM
sdhotwn's Avatar
Could be a damaged rim...
Could be improperly torqued lug pattern (if you don't torque them in the right sequence you can actually **** the tire slightly...)
Could be a damaged control arm or joints
Also could be any of the other things mentioned...
So I'd say if you have had it balanced and aligned... then...
Take off each rim and put them back on tightening the bolts in a patter that if you labeled them 1, 2, 3, 4 in a circle that would go 1,3,2,4,1.... and make sure you just progressively go tighter.. don't try and torque one down tight and then do the next one... just bit by bit.
When you do this inspect the wheel and the rim each for any kind of damage, missing tread pattern, bulges etc.
Also while each wheel is off check to make sure there isn't any obvious flex in the connections to the control arm or in the rotors etc.
If that doesnt' do it... then I'd say take it to a shop and have it looked at.
Old Apr 5, 2003 | 06:27 PM
Charles1's Avatar
ok i need it get aligrned and my front left tire is worn off on the sid eof it and one of my rimse rims and see if that does it is messed up ill go replace th
Old Apr 5, 2003 | 06:39 PM
Smoktout's Avatar
you might also have a slow leak in one tire. check the air pressure, get it aligned. do you have any suspension mods?
Old Apr 7, 2003 | 02:12 PM
norcallancer's Avatar
I started to have the same problem. I noticed a wheel weight was missing. I've gotta go back and get it balanced again.
Old Apr 11, 2003 | 04:02 PM
mobius97's Avatar
Yeah I wonder this too......could be some camber adjustment needed if so. Seeing how a tire is being worn down on one side. As for the shaking sounds like a balance issue to me specially seeing it happens at hiway speeds.
blknblubkrdude
Jun 12, 2014 06:26 PM
turbotaloon95
Sep 2, 2011 07:37 PM
AboodsEvo
11
Nov 28, 2010 07:04 PM
bbyevo8u
25
Apr 16, 2010 07:23 PM
dvd_mi
39
Mar 15, 2010 09:35 AM
