Weird idle
Old May 13, 2006 | 01:14 PM
impetus19's Avatar
amby, you need a new fan switch relay. $60 from the dealer 2 minutes to install.
Old May 14, 2006 | 10:32 AM
ambystom01's Avatar
Isn't that what the recall covered? If this one's not working right it should be under warranty.
Old May 14, 2006 | 11:01 AM
impetus19's Avatar
It is the same thing that the recall covered.. but i had problems with mine again and that is what caused my bad idle in city driving my fan wasnt turning on.
They should cover it under warranty.
Old May 14, 2006 | 11:03 AM
ambystom01's Avatar
Ok cool, I'll call the dealership and get this dealt with.
Old May 15, 2006 | 07:24 AM
airlinevomitbag's Avatar
I am thinking the idle speeds up to pump the water faster to cool it down because the fan is not kicking in when it should.
Old May 15, 2006 | 06:17 PM
ambystom01's Avatar
I checked on the fan thing, and that's definitely it. Even with it being 26 degrees out the fan isn't coming on. Hopefully I'll get this dealt with this week.
Old May 16, 2006 | 02:13 PM
ambystom01's Avatar
Ok I got the car booked in for tomorrow. It was pretty funny, when I called the dealership and said I needed my car looking at, the first response was "well right now we're looking at Tuesday or later". Once I told him my problem however, I was booked in immediately.
Old May 16, 2006 | 02:46 PM
impetus19's Avatar
they probably know that it only takes a couple of minutes to fix and that they are idiots for not correcting the damn problem with the fan switch yet.
I dont know what the recall accomplished; replaced one faulty switch with another faulty switch.
Old May 17, 2006 | 05:43 PM
ambystom01's Avatar
I took the car in today, and 99$ later, it's still not fixed. They don't think its the fan controller since the fan appears to be coming on intermittently like it should be. Currently they're leaning towards a vacuum leak.
Old May 17, 2006 | 06:35 PM
ambystom01's Avatar
Could it be the throttle body? I just read some posts from people with similar problems and they also had a bored throttle body installed. I think this issue started around the same time I got the TB installed, which just so happened to be around the same time I got the recall done.
Old May 17, 2006 | 07:42 PM
ambystom01's Avatar
Anyone?
Old May 18, 2006 | 07:06 AM
Can you measure vacuum? Mine runs at 20-22 depending on the weather 19-20 on rainy days. If its leaking I would guess you would show signifcantly less.
Old May 18, 2006 | 07:11 AM
cfdfireman1's Avatar
cel
Originally Posted by ambystom01
Not sure, I'm starting to suspect based on some other posts I skimmed through that it might be related to the headers. Once I get my CEL eliminator installed I'll see if it still does it.
You apparently are having cel issues what are the codes that are present?
Old May 18, 2006 | 05:16 PM
ambystom01's Avatar
The CEL associated with the header. I just got back from the dealership and it looks like they fixed it. Apparently the throttle line was getting stuck.
Old May 18, 2006 | 09:01 PM
ThunderOZ's Avatar
Im not sure but didnt u use seafoam? Could that have anything to do with it? jst throwing out ideas....i could be wrong...
