P0135 O2 Sensor Heater
Old May 20, 2006 | 06:16 PM
LancerOfOZ's Avatar
I got a "P0135 O2 Sensor Heater Circuit Malfunction" Error. I started getting the probably 1-2 days after a Magna Flow CatBack installation. I have searched the forums and have seen a couple references in threads with other O2 sensor errors, but no one really addressed this directly. (here is my search https://www.evolutionm.net/forums/se...archid=2559824)
Is this a dead sensor (shorted). I do have a CEL eliminator on my 2nd O2, and chance the temp difference being registered because of the back O2 resistor is now causing this because of the new CatBack??? Or should I just junk it and buy a new sensor?
Honestly with it like this I am seeing NO issues AT ALL wit the car driving. Even seems to have a slightly better throttle response.
If any one has some advice I am all ears, Thanks in advance.
Old May 20, 2006 | 07:49 PM
rhyzin's Avatar
the heater circuit is just a circuit with the o2 sensor as a resistor. all it affects is the warm up time of the o2 sensor. nothing else, really. the only reason there's a light is for emission purposes.
what'd you have to splice for the o2 sim? 2 wires from the o2 sensor are for the sensor readings. the other 2 are for the heater circuit.
Old May 22, 2006 | 10:17 AM
LancerOfOZ's Avatar
I had to splice the back O2 by the cat. I had put on a header and down pipe that caused the CEL/SES. I had a cuatom cat back prior, but it was straight through no silencer int eh middle or anything. Only until the MagnaFlow went on did the CEL/SES come back on. Should I try removing the resistor on the Cat's O2?
Old Apr 28, 2010 | 10:29 AM
Meaner's Avatar
(OP: I hope you dont mind me jumping in on your post)
I too have just had encountered the "P0135 Error"
I brought it into the shop, he said it would cost $249.00 EACH o2 sensor (Part Only), and although 1 was faulty, he recommended replacing BOTH!!! =S
I've done a quick search online and have found sensor's ranging between $28-100.
Is the cheap $28 missing any parts?!? and why are there different wire counts??
prices are through this link:
http://www.autopartswarehouse.com/se...ck+Replacement
any help is greatly appreciated.
Old May 3, 2010 | 02:41 AM
Evo666's Avatar
If you're gonna use any universal o2 sensor then stick to the 4 wire as it has the right amount of heater wires. I also would stick with either Denso (oem brand) or NTK. I used a universal denso #234-4209 on my car for a few months now without any problems.
supak1111
Dec 9, 2012 01:21 PM
supak1111
Mar 23, 2012 01:57 PM
kanyonkid
14
May 29, 2008 09:21 PM
BJai02
May 27, 2007 02:39 PM
mostro
Jan 27, 2007 03:55 PM
