A/C Problem
Old May 20, 2006 | 06:40 PM
LancerOZ Boy's Avatar
A/C Problem
Those of you with OZ's, do you have any problems with your a/c? Because when i start my car it could take awile for the cold air to start working. Sometimes it starts good right away, then later on it goes back to blowing just air. It started after i put my head unit in. So it might be possible that some wires are touching around the back of the head unit. I was just wondering if anyone else had this problem. But also before my warrenty went out i told them to check it and they said there wasent a problem. But of course it doesent act up when they checked it out. So i dont know.
Old May 21, 2006 | 08:02 PM
Wallesasuaz's Avatar
re-check all your wiring and make sure you aren't touching anything tha'ts not suppose to be touched. Then, try doing things again... if you start having problems it could mean your A/C could need a recharging. Usually it'll take a min before you feel a good blast of cold air..
Old Jun 8, 2006 | 11:25 AM
KQILancer's Avatar
Mine does the same thing, it always starts cold, then it will get almost warm, then goes back to being cold, it will do this with 5 to 10 minutes intervals
Old Jun 8, 2006 | 11:30 AM
comatose721's Avatar
go to autozone. they sell a thing-a-ma-jig so you can charge it yourself. it's pretty cheap.
airlinevomitbag's Avatar
The AC will cycle like that if it needs a charge. If its borderline the clutch on the compressor will come on and off and thats why it goes cold to just air.
Old Jun 8, 2006 | 12:11 PM
Lunchb0x's Avatar
flush your coolant. maybe your car is getting to warm. i was having the same problem, and noticed my thermostat gettin up there and the ac gettin warm, flushed the radiator and now its fine. works kold as hell on startup
CharliEvo8
Jan 5, 2025 10:14 AM
neonglh
Sep 3, 2021 10:29 PM
lghtngyello03
10
Jul 22, 2016 03:26 PM
kr_3c
Jan 8, 2016 09:33 PM
fkw958
Feb 6, 2008 11:09 AM
