Idle problems
Old May 25, 2006 | 08:04 PM
comatose721's Avatar
Originally Posted by davemiro
Comatose,
DO you think the plugs are causing any problems? i have heard that the bosch's are not good. should i throw some ngk's in and be done with it?
i would change the plugs. the car comes with Iridium plugs to begin with. if you can pick up a set of those it would be ideal.
Old May 26, 2006 | 11:46 AM
sdhes's Avatar
on a side note, is there any spray cleaner i can shoot right into throttle body. I used to use this stuff on my civic back in the day, and it made black smoke, but after word, it ran like a champ.
Sea Foam, there is a whole thread on it.
Old May 26, 2006 | 11:50 AM
sdhes's Avatar
Originally Posted by comatose721
LMAO
dude; i'm sorry. i am an unpublished author. spelling and word choice are a pet-peeve of mine. i wasn't calling you stupid; nor was i calling myself a genius
...about your post script: that just made my day. i'm still all doped up from surgery and i just accidently ripped out 4 of the 9 stitches in my mouth
happy mod'n
mark
Its all good, I'm just glad you took it the way I meant it. Carefull with those stitches my man, and glad I brought a smile to ya after surgery and all. Have a nice holiday
Old Jun 7, 2006 | 06:35 PM
davemiro's Avatar
Happy to inform you guys i changed the plugs back to new stock ones and so far so good. hopefully for good so i can pop in the header and piggy.
Old Jun 7, 2006 | 08:49 PM
cool. glad it worked out for ya
Old Jun 12, 2006 | 06:11 PM
davemiro's Avatar
Alright- not out of the woods yet....been driving the car for a while and no idle probelms. i turn on the ac and it almost dies. it idles fine at normal times like around 600-700 rpm, but when ac turned on- goes up to 1000 rpm and then drops to between 300 and 400 rpm and stays there(bounces in between a little.) when i turned on the heater it rose to 1000 and bounced between there and 1200 rpm. this crap is wierd. HELP?
Old Jun 12, 2006 | 07:24 PM
the AC pump is parasitic. when you turn it on your idle will increase in effort to compensate for the power loss. after a short period of time the idle should drop back down to 600-800rpm's. however, if your vehicle idles exceptionally low without the AC on (i idle at about 525rpm's), you can expect it to drop the way yours is.
on super hot days my car will stall out a lot at traffic lights when the AC is on. i need to up the idle.
Old Jun 12, 2006 | 08:22 PM
davemiro's Avatar
okay, but before this all happened, i used to idle between 600-800, and when the ac went on, it rose to 1100 and stayed there till the pump went off and dropped to 600
Old Jun 12, 2006 | 09:00 PM
temperature changes can account for change in idle speed. there are lots of variables that could effect it.
Old Jun 13, 2006 | 07:02 PM
davemiro's Avatar
ya think there is any way that i need to clean the throttle body or maf sensor?
Old Jun 13, 2006 | 07:22 PM
davemiro's Avatar
ok! i have searched hi and lo for any threads on cleaning the throttle body and maf sensor and have found nothing-zilch-nada! any help?????????
Old Jun 13, 2006 | 08:17 PM
just remove your intake, unbolt the TB (it's 4 bolts), and disconnect the lines that lead too it (make sure the coolant lines dont leak everywhere). put the TB on your bench and use some carb/choke cleaner to remove any carbon build up. make sure it's clean and dry; put it back together. it's simple.
Old Jun 13, 2006 | 08:45 PM
davemiro's Avatar
cool, is that the same for the maf sensor also?
Old Jun 14, 2006 | 06:49 AM
i don't know how to clean the MAF sensor. whatever you do just don't use compressed air to clean the MAF sensor.
Old Jun 14, 2006 | 09:14 AM
airlinevomitbag's Avatar
Fog the intake with seafoam out of spray bottle. Take the filter off start the car and start fogging. Never tried it myself but if I wanted to clean the MAS and throttlebody thats what I would do.
