Battery/alternator problem - help?
Old Jun 3, 2006 | 07:39 PM
lancerboy03's Avatar
i been having trouble with my car. out of no where my battery dies and its dead dead i cant recharge it . its the factory battery. I noticed my car had trouble cranking and I put a different battery on it that was good and it didn't charge it up. Anybody else have or had that problem? What could I do?
Old Jun 3, 2006 | 07:48 PM
Fa$[- a$ $hi[-'s Avatar
if you put in a known good battery and the car still didn't charge it, your altenator might be bad. start the car. take off the positive battery cable while engine is running. if the car dies, it's either your altenator or the voltage regulator, but most likely your altenator.
but, before you do that, make sure the connections are clean and free of corrosion.
Old Jun 4, 2006 | 05:41 PM
N1te's Avatar
www.car-parts.com A new alternator is around 50 bucks. Also make sure you're belt isn't loose.
Old Jun 5, 2006 | 06:42 AM
airlinevomitbag's Avatar
Check your voltage with the car off. Should be just above 12 volts. Start the car and check it again, a properly working alternator puts out just above 14 volts.
Old Jun 5, 2006 | 06:47 AM
Ahnospell44's Avatar
that is the best way to diagnose, if your alternator is dead, I used to do that all the time back in the garage when cars came in complaining of dieing. Then use the tester idea.
+1 Fa$[- a$ $hi[-
Old Jun 5, 2006 | 08:25 AM
cool thanks for the help i will get back if anything works
Old Jun 5, 2006 | 07:37 PM
Blacksheepdj's Avatar
Renamed. Moving to correct forum.
zero9243
Lancer Engine Tech
10
Oct 22, 2024 06:11 PM
Dragking2189
12
Feb 6, 2010 06:42 PM
9evolution
Nov 2, 2008 08:44 PM
zero9243
Lancer Troubleshooting
Apr 20, 2008 12:49 PM
J8dailo
Jan 25, 2008 10:13 AM
