Blowing Power Window Bus Fuses....
Old Jun 26, 2006 | 04:47 AM
The_Racing_Rev's Avatar
Angry Blowing Power Window Bus Fuses....
I am new to the forum and have really enjoyed reading everyone's posts. I haven't found anyone who is blowing the power window bus fuse yet. So to begin, the fuse blew as soon as it touched the posts. I am getting 31 amps when the car is off and 37 amps when it is running. I have disconnected all the window motors and the switches at the doors and nothing changed. Is there a relay somewhere inbetween the fuse panel and the main switch? The plugs at the passenger and drivers doors were all gunked up with dielectric grease or silicone and it had turned black on the bottom. I cut and fixed both harnesses and nothing seems to work. We have had a lot of rain here over the past couple of days but this is the only fuse that blows. I have spent 2 straight days working on this mess, does anyone have any suggestions? It is really hot now and the air conditioning is nice but really bogs down the car and I can't enjoy the nice weather with the windows down! Thanks for any help you have..........
Old Jun 26, 2006 | 07:17 AM
airlinevomitbag's Avatar
You have a multimeter I'm assuming since you know the amperage. Unplug the the power windows and test each on the pins to ground and follow it back from there.
Old Jun 26, 2006 | 09:57 AM
Easy enough to do with time, I was hoping someone has seen this already and had a helpful hint or possible fix before I tear all the panels off again. The amperage is constant even with the car turned off so I think it may be in the engine compartment or the fuse panel itself. I don't think there should be power to the window switches with the key turned off. Anyway I will pull the fuse box tonight and check for water......
Old Jun 27, 2006 | 09:18 AM
KillerBee's Avatar
Are you sure you're reading your ammeter right? 31 amps is a heck of a lot for a power window motor. It's no wonder the fuse blew... gotta be a short somewhere.
Old Jun 27, 2006 | 12:14 PM
It was a direct short, the back of the fuse panel under the dash where the relays plug in had some shotty wiring. I pulled the relay and fixed the wiring in the back and the problem went away. I am finding all kinds of short cuts taken at the factory with the wiring. I guess I finally have an excuse to get an EVO!! Anyway thanks for the help.........
Old Jun 27, 2006 | 12:47 PM
I got lots of excuses to get an EVO but sadly excuses have no cash value.
04Ralliart96
Feb 22, 2016 09:54 PM
kr_3c
Jan 8, 2016 09:33 PM
Poltergeist
Lancer Troubleshooting
Aug 15, 2015 07:53 PM
smokem22
Aug 13, 2009 07:00 PM
