Anyone have access to FULL TSBs???
Old Dec 14, 2006 | 11:47 AM
ddcha's Avatar
Looking for the full technical service bulletin report for 0635002 NHTSA number: 10019650
Old Dec 14, 2006 | 11:56 AM
Smike's Avatar
http://www-odi.nhtsa.dot.gov/cars/pr.../tsbsearch.cfm
Office of Defects Investigation
Technical Service Bulletins - Search Results
Report Date : December 14, 2006 at 02:54 PM
SEARCH TYPE : VEHICLE
YEAR : 2004
Make : MITSUBISHI
Model : LANCER
Make : MITSUBISHI Model : LANCER Year : 2004
Manufacturer : MITSUBISHI MOTORS NORTH AMERICA, INC.
Service Bulletin Num : 0613009 Date of Bulletin: APR 01, 2006
NHTSA Item Number: 10019927
Component: FUEL SYSTEM, GASOLINE:FUEL INJECTION SYSTEM
Summary:
THE MIL MAY COME ON AND DTC P0171 SYSTEM TOO LEAN MAY SET IN THE PCM. *TT
Service Bulletin Num : 0635002 Date of Bulletin: MAR 01, 2006
NHTSA Item Number: 10019650
Component: SERVICE BRAKES, HYDRAULIC
Summary:
REAR BRAKE NOISE. *TT
Service Bulletin Num : 05002 Date of Bulletin: DEC 01, 2005
NHTSA Item Number: 10017671
Component: POWER TRAIN:AUTOMATIC TRANSMISSION:CONTROL MODULE (TCM, PCM)
Summary:
EMISSIONS RECALL CAMPAIGN - INCORRECT PARAMETERS IN THE PCM SOFTWARE THAT MAY ALLOW A MALFUNCTION IN THE VEHICLE SPEED SENSOR TO GO UNDETECTED BY THE ON-BOARD DIAGNOSTIC SYSTEM (OBD). *TT
Service Bulletin Num : 0534002 Date of Bulletin: DEC 01, 2005
NHTSA Item Number: 10017673
Component: SUSPENSION:FRONT:CONTROL ARM:LOWER ARM
Summary:
REAR LOWER ARM PILLOW BALL BUSHING REPLACEMENT - SERVICE MANUAL REVISION. *TT
Service Bulletin Num : 0555004 Date of Bulletin: DEC 01, 2005
NHTSA Item Number: 10018940
Component: VISIBILITYEFROSTER/DEFOGGER SYSTEM
Summary:
INSUFFICIENT HEATER PERFORMANCE. *TT
Service Bulletin Num : 0535004 Date of Bulletin: OCT 01, 2005
NHTSA Item Number: 10017674
Summary:
BRAKE DISC THICKNESS SERVICE SPECIFICATION & RUN-OUT CORRECTIONS - SERVICE MANUAL REVISION. *TT
Service Bulletin Num : 0523004 Date of Bulletin: JUL 01, 2005
NHTSA Item Number: 10016754
Summary:
2-3 SHIFT FLARE. *TT
Service Bulletin Num : 0517001 Date of Bulletin: MAY 01, 2005
NHTSA Item Number: 10015820
Component: VEHICLE SPEED CONTROL:CRUISE CONTROL
Summary:
CRUISE CONTROL DIAGNOSIS - SERVICE MANUAL REVISION. *TT
Service Bulletin Num : 115 Date of Bulletin: APR 01, 2005
NHTSA Item Number: 10015711
Component: ELECTRICAL SYSTEM
Summary:
DIAGNOSTIC TROUBLE CODE (DTC) P0181 UPDATE. MITSUBISHI TECH TALK. *TT
NHTSA Item Number: 10015714
Component: ENGINE AND ENGINE COOLING:COOLING SYSTEM:RADIATOR ASSEMBLY
Summary:
COLLAPSED UPPER RADIATOR HOSE. MITSUBISHI TECH TALK. *TT
Service Bulletin Num : 0513006 Date of Bulletin: APR 01, 2005
NHTSA Item Number: 10016133
Component: ELECTRICAL SYSTEM:ALTERNATOR/GENERATOR/REGULATOR
Summary:
ALTERNATOR FR TERMINAL VOLTAGE - SERVICE MANUAL REVISION. *TT
Service Bulletin Num : 0554001 Date of Bulletin: FEB 01, 2005
NHTSA Item Number: 10015337
Component: ELECTRICAL SYSTEM:BATTERY
Summary:
BATTERY LOAD TEST RATE CHART - SERVICE MANUAL REVISION. *TT
Service Bulletin Num : 0413007 Date of Bulletin: FEB 01, 2005
NHTSA Item Number: 10008812
Summary:
POWERTRAIN CONTROL MODULE (PCM) REPROGRAMMING FOR DIAGNOSTIC TROUBLE CODE (DTC) P0300 RANDOM MISFIRE. *TT DRIVEABILITY CONCERNS. MITSUBISHI TECH TALK. *TT UPDATE. *TT
Service Bulletin Num : 113 Date of Bulletin: JAN 01, 2005
NHTSA Item Number: 10015210
Summary:
DIAGNOSTIC TROUBLE CODE (DTC) P0300 COLD ENGINE MISFIRE. *TT
NHTSA Item Number: 10015211
Summary:
DIAGNOSTIC TROUBLE CODE (DTC) P0335 AND/OR P0340 WITH MALFUNCTION INDICATOR LAMP (MIL) ON. *TT
NHTSA Item Number: 10015217
Summary:
BRAKE BLEEDING PROCEDURES. *TT
Service Bulletin Num : 04006 Date of Bulletin: DEC 01, 2004
NHTSA Item Number: 10016860
Component: EQUIPMENT:OTHER:LABELS
Summary:
AIR BAG WARNING LABEL SERVICE CAMPAIGN. *TT
Service Bulletin Num : 0411005 Date of Bulletin: DEC 01, 2004
NHTSA Item Number: 10016864
Component: ENGINE AND ENGINE COOLING:ENGINE:GASOLINE:BELTS AND ASSOCIATED PULLEYS
Summary:
ENGINE TIMING BELT TENSIONING PROCEDURE - SERVICE MANUAL REVISION. *TT
Service Bulletin Num : 13 Date of Bulletin: DEC 01, 2004
NHTSA Item Number: 10018361
Summary:
DIAGNOSTIC TROUBLE CODE P0300 COLD ENGINE MISFIRE. MITSUBISHI TECH TALK. *TT
NHTSA Item Number: 10018362
Summary:
DIAGNOSTIC TROUBLE CODE P0335 AND/OR P0340 WITH MALFUNCTION INDICATOR LAMP ON. MITSUBISHI TECH TALK. *TT
Service Bulletin Num : 12012004 Date of Bulletin: DEC 01, 2004
NHTSA Item Number: 10018380
Component: SERVICE BRAKES, HYDRAULIC:PEDALS AND LINKAGES
Summary:
SPORT PEDAL INSTALLATION TOOLS. MITSUBISHI. TECH TALK. *TT
Component: VEHICLE SPEED CONTROL:ACCELERATOR PEDAL
Summary:
Service Bulletin Num : 0413001 Date of Bulletin: NOV 16, 2004
NHTSA Item Number: 10011773
Summary:
DIAGNOSTIC TROUBLE CODE (DTC) P0300 RANDOM MISFIRE. *NM
Service Bulletin Num : 0454003 Date of Bulletin: AUG 01, 2004
NHTSA Item Number: 10010505
Summary:
IMMOBILIZER SYSTEM INFORMATION UPDATE (2004 MODELS). *TT
Service Bulletin Num : 07012004 Date of Bulletin: JUL 01, 2004
NHTSA Item Number: 10014142
Summary:
ENGINE BOLT LOCATION. *EH
NHTSA Item Number: 10014145
Summary:
OIL PAN BOLT. *EH
Service Bulletin Num : 06012004 Date of Bulletin: JUN 01, 2004
NHTSA Item Number: 10014372
Summary:
ENGINE BOLTS LOCATION. *EH
Service Bulletin Num : 05012004 Date of Bulletin: JUN 01, 2004
NHTSA Item Number: 10014373
Summary:
OIL PAN BOLTS. *EH
NHTSA Item Number: 10014375
Summary:
RADIATOR HOSE COLLAPSED. *EH
Service Bulletin Num : 05012004 Date of Bulletin: MAY 01, 2004
NHTSA Item Number: 10014355
Summary:
NOISE ON COLD START. *EH
Service Bulletin Num : 0442A001 Date of Bulletin: MAY 01, 2004
NHTSA Item Number: 10007558
Component: EQUIPMENT:ELECTRICAL
Summary:
REMOTE KEYLESS ENTRY (ALL 2004 MODELS). *TT
Service Bulletin Num : 0411001 Date of Bulletin: JAN 01, 2004
NHTSA Item Number: 10005838
Summary:
BLOCK HEATER INSTALLATION. *TT
Old Dec 14, 2006 | 11:58 AM
Smike's Avatar
Ah, but they charge you too sorry - wait, its a gov't office...
Old Dec 14, 2006 | 11:59 AM
clarkkent06's Avatar
I love how it took the ":" and the "D" and made the smiley
Old Dec 14, 2006 | 12:00 PM
drewblueeye's Avatar
I have full access to TSB's i got a subscription to alldatapro.com. what do you want to know?
Old Dec 14, 2006 | 12:01 PM
year? make? model? engine? it may be a stupid question but if you want to know what it is and how to fix it then i need to know
Old Dec 14, 2006 | 12:26 PM
ddcha's Avatar
Just want the full report for TSB: 0635002 NHTSA number: 10019650
I have a 2004 Lancer Ralliart Sportback. Have this aweful break noise in the rear when I go in reverse only. Plenty of pad left, so it's not that.
Old Dec 14, 2006 | 12:49 PM
this is copy and pasted from alldatapro.com
No.: TSB-06-35-002
DATE: March 10, 2006
MODEL: See below
SUBJECT:
REAR BRAKE NOISE
PURPOSE
On some affected vehicles, customers may complain of brake noise during light brake pedal application when backing up at slow speeds, typically when the brakes are cold. To improve this condition, replace the rear brake pads using the new, improved parts listed in this bulletin.
AFFECTED VEHICLES
2004-05 Lancer Ralliart and Lancer Ralliart Sportback produced before 11/1/05
PROCEDURE
If brake noise occurs during light brake pedal application, replace the rear brake pads on both sides, using the new, improved pads listed below. Refer to Group 35 in the appropriate service manual.
PARTS INFORMATION
Use the Genuine Mitsubishi Parts listed below.
Description Part Number
Rear Brake Pad Set 4605A336
WARRANTY INFORMATION
Rear Brake Pad Replacement
Nature Code: 54J Cause Code: 600
Labor Operation No. 35262610 Time Allowance: 0.5 hr.
Warranty Coverage: Basic coverage (3 years/36,000 miles or 5 years/60,000 miles depending on vehicle sale date)
Special Warranty Information: Rear brake pad replacement on customer complaint basis only. Not to address brake pad wear issues or normal maintenance needs
Old Dec 14, 2006 | 12:57 PM
ddcha's Avatar
Awesome. Free fix here we come!!!!
Old Dec 14, 2006 | 01:33 PM
Qest's Avatar
Cool, how about the 2006 Mitsubishi Lancer Evolution IX?
Thanks!
Old Dec 14, 2006 | 02:11 PM
Qest,
Are you asking if there is a Recall for your car? if so do you have a number? there is only 7 TSB's for the IX, none for the brakes, though
Old Jan 24, 2007 | 10:28 AM
Pharaoh04's Avatar
I am looking for the Full version of the following TSB... The dealership I took my car too never did a rear allignment after replacing the bushings and now I have 2 shot rear tires. They are telling me it's not their fault cause the TSB said that service did not require an alignment while every other mechanic (including the one at the Mitsu dealership I went to yesterday) said whenever anything is done to the rear suspension an alignment should be done. Can anyone help me out here?
Summary:
Old Jan 24, 2007 | 12:18 PM
SLVROZ_03's Avatar
So are these the "complete" lists of dealer defects that "have to" be replaced/fixed by the dealer per the manufacturer for free? If so, could I have a list for the '03 Lancer OZ Rally w/ an auto tranny? Post it or PM me, either way... This way I can reference this to other people's Lancer problems that are posted on here.
Thanks!!!!
Old Jan 24, 2007 | 01:38 PM
Silens's Avatar
wow, could you look up this one:
Summary:
thanks
Old Jan 25, 2007 | 06:50 AM
Blacksheepdj's Avatar
Summary:
thanks
I do not see that on the TSB list...
