intermiitten and slow starting HELP!!!
Old Feb 26, 2007 | 09:19 PM
03lances's Avatar
OK guys I have an 03 ES and when I go to start it, it is very slow cranking over like the battery is almost dead. However I tried another battery I knew was good and same thing. Also some times it wont do anything when I turn the key over like the batt is completely dead, not even clickin noise.
I have already tested the alternator and the battery. The battery leads are all brand new I changed them less than a month ago. And it seems to be getting plenty of fuel. Sometimes it will also start up like normal!!!???? Once started it runs like normal I just dont get it HELP GUYS!!!!! thanks.
Old Feb 26, 2007 | 09:30 PM
namrepus's Avatar
Ohm out the starter
Old Feb 26, 2007 | 09:37 PM
eponti's Avatar
i had the same problem with my evo 2 months ago.Come to find out i lost one of the grounds.I dont know if the engine bay is the same but i have a ground wire hooked up from my intake manifold to the chassis .Look real close that might be your prob.
Old Feb 27, 2007 | 08:29 PM
03lances's Avatar
Awesome thanks guys those are two things I have planned to check into. I have replaced the ground from the frame to the engine and that didnt seem to do a whole lot. also the battery leads are brand new. I am going to continue looking for bad grounds if any of you have suggestions of grounds to check please let me know Thanks again.
zero9243
Lancer Engine Tech
10
Oct 22, 2024 06:11 PM
newblancer
Lancer Engine Tech
Jul 1, 2016 09:35 PM
usmcrfu
Lancer Troubleshooting
Dec 6, 2012 06:01 PM
campbmic
Lancer Engine Tech
14
Aug 22, 2010 07:35 PM
Silentbob812
Sep 7, 2008 10:11 AM
