Need Oz Ecu Wiring Diagram
Old Jun 5, 2003 | 01:36 PM
nightrider's Avatar
as the title says i need the diagram. i have searched but only got pics that i couldnt understand. i want a diagram like this one
http://www.roadraceengineering.com/e...-ecuwiring.htm
so if you can help me out please do so. i need it for tach and a/f install.
Old Jun 5, 2003 | 02:14 PM
HobieKopek's Avatar
https://www.evolutionm.net/models/la.../wirediag.php?
Old Jun 5, 2003 | 02:17 PM
nightrider's Avatar
ok thanks for the diagram but i cant understand it. could you just tell me which diagram is for the ecu box behind the glove?
Old Jun 5, 2003 | 02:19 PM
uranium9v's Avatar
Do a search for AFC diagram...loook for posts by rhyzin, he took an actual photo of the ecu and labeled everything quite well.
Old Jun 5, 2003 | 02:20 PM
HobieKopek's Avatar
Nope. I've never spent any time trying to read one and I'm certainly not going to learn at work. Possibly someone else could help you, but asking someone to name all the pins is an awfully big favor. You may want to find out exactly what pinouts you need, ask for them, and not worry about the rest if you want a quick answer.
Old Jun 5, 2003 | 02:23 PM
rhyzin's Avatar
here, this should be it. i feel helpful today. just got my wisom teeth pulled an hour ago. legal drugs are great!
https://www.evolutionm.net/forums/sh...ht=rhyzin+safc
Old Jun 5, 2003 | 02:25 PM
uranium9v's Avatar
thats the one!!!
Old Jun 5, 2003 | 02:27 PM
nightrider's Avatar
damn thanks for the help ppl. i actually saw this thread while searching but i guess i didnt let the picture load and skipped it. ill go install the guages and hope everything is right.
Old Jun 5, 2003 | 02:47 PM
HobieKopek's Avatar
Out of curiousity (and since it's related to the AFR guage install) where does the stock AFR reading come from? Is it based on the MAF value or does it actually measure like a narrowband O2 sesor?
Old Jun 5, 2003 | 02:50 PM
uranium9v's Avatar
comes off the O2 bung on the header, but I noticed it wouldn't read if the MAF wasn't connected.
Old Jun 5, 2003 | 03:20 PM
rhyzin's Avatar
oh boy, do i feel great. good luck with the installs.
Old Jun 5, 2003 | 03:58 PM
rhyzin's Avatar
for those with an automatic, here's the harness diagram for the m7-e
Old Jun 6, 2003 | 04:16 PM
nightrider's Avatar
ok i have my tach hooked up to the ecu rpm signal but its 200rpm off. its about 100 rpm off under 2k but above that it gets about 200-3-- rpm off. i have a pivot tach. its suppose to be good but it is not reading right. could it be that the rpm signal in the dash is off? or is the tach messed up? any suggestions?
Old Jun 6, 2003 | 04:59 PM
rhyzin's Avatar
the rpm on the dash is wrong. my dash rpm is 200 under what it says on my SAFC. i think i trust my SAFC more since it's digital.
Old Jun 6, 2003 | 11:01 PM
nightrider's Avatar
ok good i think thats makes me feel better. thought i hooked it up wrong or something. ok completely off topic but i was driving in rain today and then my motor out of nowwhere kind of bogged or something for like 5 secs. is this water getting in the intake?
