Low Idle
Old May 6, 2007 | 06:52 PM
fkedke's Avatar
Low Idle
Ok so here is my problem. I went cheap and bought a Lancer instead of an Evo. No just playing. But seriously, my 02 Lancer ES has always idled around 900-1k. Recently it has been idling around 500-600. This was not too big of a problem however, when I put it into gear (automatic) the revs drop around 200 and the car is frequently shutting off. I first noticed this when the car shut off going around a slow turn. Since then, I have checked the spark plugs and wires, and while one plug was gapped wrong, I adjusted it and the problem persists. Any ideas.
Old May 7, 2007 | 06:38 AM
blaze_125's Avatar
Change plugs, inspect and change wire plugs if needed, inspect and change coils if needed.
Your issue sounds "fire" related.
Run a bit of Seamfoam in you Intake Manifold and fuel lines. It will clean the crap out of it, and may help with your problem.
Old May 7, 2007 | 02:40 PM
johnd651's Avatar
i had the same problem in a probe i had...
i changed the ignition wires, plugs, and coils and the problem was gone....maybe try that
Old May 7, 2007 | 04:28 PM
SLVROZ_03's Avatar
Could be as simple as un-hooking the battery to reset it...? Try that "free" mod first!
Old May 7, 2007 | 08:41 PM
fkedke's Avatar
Any idea how much coil packs cost
Old May 9, 2007 | 01:23 AM
evilevo22's Avatar
bump
Old May 26, 2007 | 05:02 AM
mrblob20's Avatar
coils are 100 bux each, i had to replace mine twice. Usually u get a misfire code if ur coils are dead... i have the same problem, but when i put my car in neutral, i get really low idles, and even my oil light starts to flicker .. isn't there a way to increase idles.. id like mine to sit at 900.
Old May 27, 2007 | 04:01 PM
mrblob20's Avatar
i fixed my idle problem... i searched the forum lol
Old May 27, 2007 | 07:27 PM
Noe18's Avatar
how did u fix it and 2 get it back up 2 900
Old May 27, 2007 | 08:57 PM
mrblob20's Avatar
like right on top of the throttle body, on the right of the bell shaped thing, there is a flat rubber plug.. remove it, and turn the phillips screw counter clockwise until you get the idle you want it to be. then put the plug back on there. U should reset the ecu too cuz now when im in neutral, it idles higher than it does if im driving. which is weird.
Old May 28, 2007 | 11:01 AM
Defcon5Es's Avatar
can you show a pic mrblob20 thanks
Old May 29, 2007 | 04:16 AM
mrblob20's Avatar
https://www.evolutionm.net/forums/at...5&d=1144545572
Old May 29, 2007 | 05:20 AM
Noe18's Avatar
hey myblob20 does it work for a auto tranny
Old May 29, 2007 | 12:24 PM
mrblob20's Avatar
yea mine is an automatic too.
Old Jun 4, 2007 | 12:45 PM
krimson_binome's Avatar
You could also try cleaning or replacing your air filter. If it is too dirty (and restrictive) it will cause your idle to drop.
jb988
Lancer Engine Tech
Aug 10, 2015 07:10 PM
Latino evo
Feb 6, 2014 09:14 AM
evoforlife
Feb 13, 2011 04:26 PM
joedr
Aug 22, 2008 01:11 PM
jeffreyinigo
Apr 7, 2007 12:42 AM
