Evo 8 idle problem
Old Feb 3, 2014 | 07:29 PM
Latino evo's Avatar
Evo 8 idle problem
I just purchase an evo im having problems with the idle it start to shake alot when i got the a/c running and the car is at a stop it almost feels like it want to shut off put it stay at 900 to 1000 rpms feels like a misfire but when its driving it running perfect. So far what it has done is a recirculating bov by forge with injen piping, has a dump tube full down pipe exhaust boosting at 20 to 21 psi i was able to to lower the idle abit because when i purchase it it was idling at 1300 rpm. I also bought new spark plugs. If anybody has a suggestion please help thank you.
Old Feb 3, 2014 | 07:36 PM
Viegasjuice's Avatar
I would check for a possible boost leak. Could also be tune related.
Old Feb 3, 2014 | 07:37 PM
Bhsj13's Avatar
It sounds like you need to have it tuned. Mods in my sig and my car idles fine with AC on/off.
Bhsj13's Avatar
Or like viegas said, check for leaks.
Old Feb 3, 2014 | 08:00 PM
detroit pistins's Avatar
So does it idle OK when the AC is off?....how about AC on while idling at 1300 rpm, was it ok then?
Old Feb 4, 2014 | 05:41 AM
Latino evo's Avatar
When the a/c is off it idles fine I think it sounds like it has a cam not to aggressive. But after a good while drive is starts a bit but not to bad
Old Feb 5, 2014 | 04:53 PM
Latino evo's Avatar
What could it be.
Old Feb 5, 2014 | 05:07 PM
chintrebor's Avatar
did you check the iac? idle air control
Old Feb 5, 2014 | 05:25 PM
Robbyevo's Avatar
id say its the tune as well
Old Feb 5, 2014 | 05:26 PM
Robbyevo's Avatar
i don't think a boost leak would run well when driving unless you weren't in boost
Old Feb 6, 2014 | 06:07 AM
Latino evo's Avatar
It pulls fine just the idle has its weirdness I will be checking the iac and doing a boost leak test soon.
Just to make sure the iac its on the throttle body but underneath it so I would have to take the throttle body out right.
Old Feb 6, 2014 | 09:14 AM
chintrebor's Avatar
I had similar problems and it was my iac! Question, do you have to keep your foot on the throttle for cold starts? and when warmed up it runs fine? yes it's on the tb and you don't have to remove it. When I did mine I removed the battery and upper I/c pipe, there's three small phillips screws holding it in place, one's a little difficult to get to, just don't lose them, and make sure the o ring is in place and sealing. Just make sure that it is what's malfunctioning first, because they run $300+ @ the dealer,or you can get them used on this forum in the classified or ebay for around $60-100+. part #1450A069 - IDLE SPEED CONTROL
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
Pho3nix
Sep 18, 2013 08:05 PM
DanJ
Sep 6, 2013 03:01 PM
Turbodhatch94
May 27, 2012 10:47 AM
lancerrallygirl
Feb 15, 2009 06:57 PM
