Car Stutters during take off, almost no power... picks up when u floor it.
Old Sep 22, 2007 | 11:44 AM
  #61
Mirage2.0's Avatar
PM sent back.
Old Sep 27, 2007 | 02:48 PM
  #62
Skipper Viii's Avatar
My Lancer is experiencing the same sort of difficulties. The CEL just came on 2 days after buying the car used. I have 77KM's and the car seems unresponsive after stopping. I'm going to change the air filter and have a look at the spark plugs. Hopefully it isn't a lingering problem like you guys have been experienced.
Old Sep 27, 2007 | 08:48 PM
  #63
Tech@SA573's Avatar
Yeah, maybe it'll be something simple in your case. As for me, I have a cam position sensor on the way now. I'll be sure and let you all know if that fixes the problem with my car.
Old Sep 28, 2007 | 04:33 AM
  #64
Can you guys recommend a good brand for Spark Plugs?
Old Sep 28, 2007 | 04:43 AM
  #65
Tech@SA573's Avatar
NGK BKR5E-11 are what you want. You don't need anything special.
Old Oct 5, 2007 | 09:22 PM
  #66
Tech@SA573's Avatar
Well, for anyone interested, the cam position sensor didn't fix my problem. If anyone would like to see if it fixes their issue, I now have an extra one for sale.
So anyone have any other ideas?
Old Oct 5, 2007 | 11:19 PM
  #67
kungfugirl's Avatar
I had an issue where my car had NO power. Felt like 2 hp then i would keep my foot down and it would CHARGE!!! It was a bad o2 sensor.
Old Oct 17, 2007 | 11:23 PM
  #68
dhahlen's Avatar
I need to replace the o2 sensor. O.E. one is $80+
What do they use? 4 wire? Worth getting one of ebay? Heh
Old Oct 19, 2007 | 07:08 AM
  #69
Tech@SA573's Avatar
Yeah they're 4 wire. You can get them here for ~$50.
And to kungfugirl:
Were you throwing a code for the O2 sensor before you replaced it?
Old Oct 22, 2007 | 03:17 PM
  #70
dhahlen's Avatar
Replaced o2 sensor...
Engine light went off when i started...
Drove a little bit, it misfired again and light came back on... heh
Old Oct 23, 2007 | 01:01 PM
  #71
Tech@SA573's Avatar
What code is it throwing?
Old Oct 24, 2007 | 02:46 PM
  #72
dhahlen's Avatar
Was misfire on Cylinder #2
Anyway - I replaced the plugs... after pulling them all apart I noticed all of them had a brown ring around the plug... looks like they were burning out.
I should be kicking myself in the teeth and you'll see why in a bit....
I went out and bought some NGK's for $1.99 a pop, I am an avid NGK fan and use them in my rotary... love them. I had previously put in Bosch plugs... why? Who knows..? The bosch plat 2's were $4.99 a pop vs the $1.99 NGK resistor types I had put in this morning. Bosch makes the crappiest plugs ever.....I'll never use them again.
The check engine light is on but hopefully it will go away. I took it for a test drive around the block - very responsive, and no stuttering.
My wife drop it to work this morning, roughly 20 miles street/highway and she said it did not stutter and noticed a significant increase in throttle response and acceleration.
Seems the NGK + o2 sensor fixed the issue... for now. =) Lets hope it doesn't torment me any longer. I'll post more updates if things begin to happen again.
Old Oct 26, 2007 | 08:22 AM
  #73
xLancerOZx's Avatar
I also had the stuttering prob. I changed spark plug wires and spark plugs and put some injector cleaner. Came out nice .
seems im passing mini vans faster now
Old Nov 15, 2007 | 06:07 AM
  #74
bspsrt-4's Avatar
Well how's it running? My lancer acted the same way, New plugs and coils always fixed it for about 10,000 miles. Then it goes back to running like crap. It starting to cost to much to keep it running. Is there something in these cars that would keep killing the coils.
Old Nov 15, 2007 | 07:01 AM
  #75
lancer2show's Avatar
this happened to my cousins 3g. after new spark plugs it worked fine. gapping is very important.
