Lancer AUX Ports....bad sound?
Old May 21, 2007 | 01:25 PM
grandroyal's Avatar
Has anyone tried to put an iPOD into their AUX ports yet? I got really bad sound when I tried it, like sound only coming out of one side of the speakers. Im going to try more devices soon but anyone else have this problem?
Also...the guy at the dealership claimed that the little silver "input" or whatever it is on the lower left side of the DVD/Nav screen (not visible when closed when screen is closed) was also an iPOD hookup. This can't be right...right?
Old May 21, 2007 | 05:02 PM
gnnr's Avatar
that can't be a functional input, unless it's meant to run with the screen open which would be dumb as hades. And I noticed the aux input isn't the cleanest either. The system definately shows how bad high compression MP3s can sound, that's for sure.
Old May 22, 2007 | 07:02 AM
BlueLynx's Avatar
Mine sounds fine, the only thing is if there is a long silence in a song you can sort of hear a faint "whirrrr" sound but that is only if the volume on the stereo is up really loud.
I use a Belkin mini to RCA cable that I got from Walmart for 5 bucks. It has been the best 5 bucks I have spent in a while.
Old May 22, 2007 | 07:11 AM
grandroyal's Avatar
Thanks I'm hoping it was just my friends cable
Old May 22, 2007 | 07:46 AM
Hawkeye's Avatar
Mine sounds great, unless there's nothing plugged into it. Then I get some good static.
Old May 22, 2007 | 11:22 AM
alex_GTS's Avatar
same here
Old May 23, 2007 | 08:41 PM
alex_GTS's Avatar
i just noticed that it actually sounds better if u put ur ipod at say 70 % of max volume and raise the volume from the car itself..
cuz if u put ur ipod at max volume its not gonna be as good..
hope this helps
peace
Old May 23, 2007 | 09:29 PM
Blacksheepdj's Avatar
Yeah, iPod should always be at 50-75% volume when it's being run through a cable or adapter like that.
Old May 24, 2007 | 06:17 AM
Turbo Dizzle's Avatar
I am using the Microsoft Zune and I put it basically to 18 and turn off all Equalizers Pre set. But when I power it off I hear a slight buzzing noise. Which ususally sounds like the power to the stereo is dirty. Basically I am having the same problem.
Old May 24, 2007 | 10:21 AM
When I turned off the iPod today, I got a static as well. So if the MP3 player is off, make sure you're set to CD or radio.
The sound quality leaves something to be desired, personally. I set the iPod volume to 75% and plugged it in and the volume was much lower than the CD I had been listening to. I had to bump the volume up 5 notches...
Old May 24, 2007 | 06:13 PM
agent712's Avatar
yeah, mine has a "whirr"ish sound as well.
Old May 25, 2007 | 04:47 AM
Lancer08GTSCVT's Avatar
I have had no issues with my aux ports or my iPod or Xbox360 that I plugged into it. So far so good.
Old May 25, 2007 | 06:50 AM
agent712's Avatar
i figured out my high pitched frequency problem, it comes from the the power cord i use to keep my ipod charged, when its unplugged it sounds fine...
Old Jun 6, 2007 | 10:13 AM
jamsterjam's Avatar
Where are the AUX ports located? I have an ES and displays AUX when I hold down the CD button for 3 seconds, meaning I have the capability to use the AUX. Just need to add the port. Any pics would help too.
Thanks.
Old Jun 6, 2007 | 10:38 AM
grandroyal's Avatar
They AUX ports should be located just under the climate controls in that area by the ash tray way in the back.
Evo209Viii
Oct 17, 2011 10:41 PM
ugakirk
Aug 14, 2010 07:47 PM
Titaztik
May 22, 2009 06:11 AM
gbert
12
Apr 29, 2008 07:32 PM
Reverence
Jan 16, 2008 03:56 PM
