Help!
Old Jun 19, 2003 | 05:43 AM
Kurt's Avatar
Question Help!
I need a little help. As I was driving to work this morning, my speedometer stopped working. I looked down and saw it stuck on 20mph. ANy suggestions? BTW, all my other gauges are working.
Old Jun 19, 2003 | 05:46 AM
uranium9v's Avatar
Mine did that a while back too...at first i would hit the gas and it would take it forever to move, then one day it just stopped working. I turned the car off and disconnected the battery for a while...worked fine again after that.
Old Jun 19, 2003 | 05:48 AM
Bitnode's Avatar
yeah, reset your ecu. turn off your car and disconnect the ground from the battery. let it sit for about 5-10 min, then re-attach the ground to the battery, turn your car back on and let it run at idle for about 20-25 min. should be ok.
Old Jun 19, 2003 | 06:17 AM
Kurt's Avatar
Thanks, I try that tonight when I get home.
Old Jun 20, 2003 | 10:32 AM
mobius97's Avatar
Do you have aftermarket gauges? Meaning Gauge face covers?
Old Jun 20, 2003 | 10:38 AM
Kurt's Avatar
I got the problem fixed. When I took my gauges apart to paint the trim together, the speedo face popped up a little and was making the needle stick. I took everything apart and made sure everything was put back together right. Lesson learned, do it right the first time. Thanks for the help everyone.
