Front end clanking sound
Old May 25, 2007 | 11:04 PM
03lances's Avatar
Hey guys I have an 03 ES and whenever I go over any little tiny dip or bump in the road on my passenger side my front wheel area had this clanking? sound coming from it. I cannot for the life of me find the problem. I took the wheel off along with the brake caliper and retorqued every bolt under there and put it all back together double checking it all. I did this twice and still the noise persists what am I missing???!! Thank in advance guys
Old Jun 1, 2007 | 11:45 PM
bobaab's Avatar
Does it sound like plastic rattling? If so, I have that too. I'm PRETTY sure it's that plastic cover thing on the underside of the car. My car seems to be missing a few of those plastic things that keep it together.
Old Jun 7, 2007 | 07:16 AM
fe2o3's Avatar
Same on my 2002. Seems like a metal clanking when you hit bumps. I've crawled around tightening anything that would, which was really nothing. I also pounded around with a rubber hammer looking for anything loose. Also nothing.
03Lances, can you see if you are applying brakes while hitting the bumps if the sounds stops or lessens? Mine seems to.
I found a thread here somewhere that mentions the drop links may be worn out and cause this noise when hitting bumps, but when you jack the car up and look, you really can't visually see it. Then they go on to say that you can't reproduce the rattle underneath yourself because there is torsion arm tension on that point so it's not loose and never really at rest. Only the weight of the car is enough to rattle it. That's a possibility, but mine lessens when I have the brakes on... I think.
All I know is it sounds really bad.
Old Jun 7, 2007 | 07:40 AM
Kurt's Avatar
Is your suspension still stock? If yes, is it the original suspension? If it is not the original, take it to whoever did you the work. Also, check you upper sturt mount. I really don't know how to tell you if that is good or bad, but back when I had my car lowered on Progress spring, that is where all my noise came from.
Old Jul 10, 2009 | 06:49 PM
03lances's Avatar
Back from the dead holy moly lol. In case anyone needs the info it turned out my lower ball joint was shot, as soon as I replaced that all was good
nukleus
Oct 28, 2015 03:30 PM
projectxmatt
Jun 27, 2014 03:28 PM
dxlykos0131
Dec 8, 2013 07:59 PM
throttledrop4
10
Apr 15, 2013 09:10 AM
ThEHiTMaN
12
Oct 12, 2006 07:49 PM
