Passenger tire is rubbing
Old Jun 25, 2003 | 11:23 AM
The EquAzn's Avatar
Hay,
I got Eibach Lowering Springs, and thats it...
So anyhoo, when i take corners to the left... my passenger side back tire rubs against the wheel well... Or there is a rubbing sound...
Have any of you experienced this? and how can i fix it? and what caused it?
Old Jun 29, 2003 | 08:49 PM
KTRLancer02's Avatar
well you didnt post whether you had different wheels on, and what size they where and what size tires. Also, IamKar had rubbing and it turned out to be that a piece of the wheel well was not bolted in because the bolt was missing causing it to hang low and caused a bit of rubbing. You need another person to turn the wheel for you while you look so you can see where the problem is coming from.
if there is a blot missing it might have been due to rough terrian, like minor off roading or just something that came lose. If you do not have bigger wheels this may be the problem, other than that you should have no rubbing.
