wtf help please low idle jerky accel
Old Jul 10, 2003 | 12:40 PM
zlaxman's Avatar
my car is idling funnylike really really low, it jerked before acceleration
what could i have messed up...
Old Jul 10, 2003 | 12:41 PM
nightrider4's Avatar
i have no clue. have you done anything to your engine lately?
Old Jul 10, 2003 | 12:43 PM
zlaxman's Avatar
no, it jsut started after i installed my aem cai, and i dont even think i installed it perfectly,...god this sucks, now we will have to take it in.
Old Jul 10, 2003 | 12:53 PM
zlancer's Avatar
no no no.......if you searched the site you would find your answer. first make sure everything is in correctly. make sure the MAS is connected. you also need to disconnect the battery for a good 15 min to reset the ecu. then you should be fine.
Old Jul 10, 2003 | 12:56 PM
diesel_fan's Avatar
Were you gentle when separating the MAS from the stock airbox when installing your intake? The MAS is somewhat delicate. As a quick test, after the car is warmed up, try the following.
Shut the car off, unplug the wire from the MAS, then start the car. The ECU should now be in 'limp mode' since it is not receiving a voltage signal from the MAS for adjusting the closed loop A/F ratio. Take the car for a short spin (no more than a mile or so) around the block to see if you're still getting the jerky throttle response. It's going to most likely smell bad since the limp mode sets a rich A/F mixture. If the car actually runs better or accelerates smoother with the MAS unplugged then somehow you've damaged the sensor itself.
If it runs the same, were any vacuum hoses or anything else disturbed when you installed the intake?
EDIT: You can try the reset ECU trick first, if you do that and you're still having problems give a shot at what I've posted.
Old Jul 10, 2003 | 12:59 PM
you also need to let the car idle for 15 mins after the install if you go out right away the ecu has not adapted yet.
psionic98's Avatar
i agree with Z and diesel, id start out with the battery discon and then recon and let it idle for 15-20mins to see if it adapts itself, if that doesnt work go with diesels... otherwise put all factory stuff back in car and try that, if still messy with stock stuff, take it to dealer and hope they don't know you took it all apart!
Old Jul 10, 2003 | 01:09 PM
diesel_fan's Avatar
Some interesting reading about resetting ecu's and the affect on long and short term fuel trims... I know it's a bit old, but I think the general theory and most of the terminology is correct since it's Mitsu based.
General Mitsu EFI Operation
Old Jul 10, 2003 | 01:18 PM
blaze_125's Avatar
You will also want to make sure nothing is in the pipe in the MAS area. The smallest thing can deviate the air and give a bad reading to the ECU causing that. Happened on my previous car
Old Jul 10, 2003 | 01:29 PM
zlaxman's Avatar
thanks guys, i jsut didnt let it idle and adaopt.
Old Jul 10, 2003 | 01:47 PM
zlaxman's Avatar
nope didnt do it, once it idles for a while it stalls...i was driving up my driveway and the steering wheel locked...almost hit my dads truck. wtf is going on.
Old Jul 10, 2003 | 01:49 PM
blaze_125's Avatar
In another tread you said you were having trooble installing the piping. How did you fix that problem. The cause might be there.
Old Jul 10, 2003 | 02:01 PM
zlaxman's Avatar
i just made it into a short ram.... so that pipe isnt there nemore....and the exhaust like goes then pauses....goes then pausres...its not the same was it was i know that..
Old Jul 10, 2003 | 02:10 PM
zlaxman's Avatar
i dont think it is shifting ne more eithner hahah
i redlined it in an auto while accelerating....that has never happened before, i just got up to like 35....and it got up to like 7500 rpm. **** **** ****
Old Jul 10, 2003 | 02:53 PM
blaze_125's Avatar
My suggestion is this.
1. Take everything appart, I know it's a pain but...
2. Use this tread to help you through the install
https://www.evolutionm.net/forums/sh...light=cai+pics
Quick question though... You're driving stick or Automatic?
