EGR Problem...
Old Nov 10, 2007 | 08:53 PM
iufan4lifeul's Avatar
EGR Problem...
Alright, so I got all of the stuff done to my car about a month or 2 ago but have been fighitng this problem ever since. I was out driving hard on the car the night I got it done... It was idleing perfect and driving like a champ. After about 45 minutes I came to a light and all of the sudden the car started to cam like it had a pure drag cam in it. The engine kept wanting to die and the car would lunge forward at idle.
The check engine light ended up coming on so I took it in and the shop scanned it and it said insufficient EGR flow... Well, vacuum line popped off probably. All vacuum lines were still very securely attached. We ran a diagnostics on the EGR system thinking the valve had gotten stuck or something but it all checked out fine. There was just insufficient vacuum. Normally the number would be around 100 or something by mine was 60... not sure what, but thats what he said. After more looking into it he thought it would just be best to cap the EGR so we blocked it completely off and it runs perfect again. He said he has seen a low vacuum at idle before on cars with race cams but even though this is a VERY mild cam that was the final determination. BUT, we pretty much know that is not the case...
My question is this.
Should I just have the whole EGR system replaced and give that a shot? What else could it be?
Also, I have noticed that my cars power has seemed to be slowly decreasing. I can't even chirp tires anymore when I used to be able to pretty easily. Would this be caused by having the low vacuum? Any help is appreciated.
Old Nov 11, 2007 | 03:21 PM
02-Lancer-Es's Avatar
mine is doing the same thing and cant figure out y and im stock just with a SRI
BUMP
Old Nov 11, 2007 | 06:57 PM
mitralliart's Avatar
the problem his a check valva in egr pipe vacuum stock , replace that small tube
Old Nov 11, 2007 | 07:02 PM
EvoDan2004's Avatar
i have the same darn issue. i have big cams though. i cant seem to keep the egr codes away. they just keep popping up. all the hoses and lines are all on right. i clear the codes and pop light go's back on after a few miles. i also need help how to fix this issue so we can pass inspection and stuff. PLEASE HELP US
Old Nov 11, 2007 | 07:24 PM
Please clarify?
Old Nov 11, 2007 | 07:25 PM
If I figure it out I will let you know. I am sure you have like 272's or bigger. Mine are just the 248's or whatever RRM's stage 1 are . Mine shouldn't be causing that problem.
Old Nov 11, 2007 | 07:26 PM
EvoDan2004's Avatar
oops i have an evo..... my bad. dose it really matter though?? i have revolver cams. mega aggressive cams for the evo.
Old Nov 14, 2007 | 06:42 PM
Bump
Old Nov 14, 2007 | 06:43 PM
hey i was just told today since i dont have the CEL on that its a vacuum leak and u can hear it if u listen closely!!
Old Nov 15, 2007 | 02:49 PM
hey i fixed it it was a dirty vac line.but one of the metals one...the one that connects the TB and the solenoid what i did was that i couldnt clean it so i just ran a hose directly and that fixed my prob for only 50 cents
fostytou
359
Oct 23, 2025 09:54 AM
EVOEvolved
21
Mar 16, 2013 08:04 AM
From 3 to E
14
Jul 27, 2012 03:09 PM
jxs1984
Oct 20, 2010 10:34 PM
