Horrible Problem
Old Nov 13, 2007 | 09:15 AM
J Money's Avatar
Originally Posted by SLVROZ_03
^Yeah, my 'ol Ford Escort had that...never did try it though, but that is a VERY good idea!
mayb its a ford thing cuz it was on my ford crown victoria..that thing was a boat lol but it was fun
Old Nov 13, 2007 | 09:51 AM
SLVROZ_03's Avatar
^ Ford ownz Mitsu in the gas door dept! LOL
Old Nov 13, 2007 | 10:46 AM
drucea's Avatar
lol ok it works the same as your trunk release. You pull the lever, which is attached to a line/cable, attached to the gas door. If the line is broken, or detached from the lever, you won't be able to pry the door open with someone holding the lever up. You'll have to find out how to get to that cable, and find out how up pops the door open. There's no emergency one in the trunk, unless they hide it really well. Good luck with it. If you have enough gas lol, go to mitsu, that should be something they fix for free or cheap, cause I doubt you have any warranty left on an 02.
Old Nov 13, 2007 | 10:54 AM
tweakdsm's Avatar
I would ask a friend, to pull the handle and you try to open it... if this dosnt help, trace the line and see if its broken, i doubt.
Old Nov 13, 2007 | 10:56 AM
saiyanzzrage's Avatar
this is probably one of the only things id go to the stealership for
Old Nov 13, 2007 | 11:14 AM
JohnnyBoy427's Avatar
I wouldnt.
It would save you a lot of gas if you checked the line. Anyone that can pull can get to it so its a job for a master mechanic. The line runs along the drivers side door sill.
Old Nov 13, 2007 | 12:02 PM
Jehuty's Avatar
The pin still pulls away, but the door won't pop open. If I pull the lever inside the door doesn't swing open, but my buddy was able to open the door with his hand when I pulled the lever without forcing. So it's somethin that forces the gas door open that's messed up
Old Nov 14, 2007 | 06:17 AM
cfdfireman1's Avatar
spring
The little spring on the hinge in broken or missing. Maybe a bit of WD-40 will do the trick.
Old Nov 14, 2007 | 10:20 AM
SLVROZ_03's Avatar
On my Civic, I had to manually bend the latch on the gas door side a bit...
Old Nov 14, 2007 | 10:50 AM
J Money's Avatar
haha right lol..cconsidering buying a mustang in the near future...mayb thatll have the lever as well
Old Nov 15, 2007 | 05:27 AM
Jehuty's Avatar
Mine doesn't have that black thing....lmao
Old Nov 15, 2007 | 01:34 PM
look...
around inside the door for it.
Old Nov 15, 2007 | 03:29 PM
Jehuty's Avatar
Yup, I looked today, and it is NOT there, so I'm gonna guess I can't do anything without it, so.....can I buy that at autozone?
Old Nov 15, 2007 | 03:58 PM
Stealership maybe or rig some kinda rubber piece that makes the door pop open when released.
Old Nov 15, 2007 | 06:13 PM
Redlancer's Avatar
It's the spring I believe, but where the hell can I get that damn thing? Besides the dealership, because something tells me that my wallet is gonna hurt, lol.
I paid 2$ or 3$ CAD for this little spring at the dealer... It's not so bad. (When I break mine with the cord that hold the gaz cap to the boby.)
