Turn lighs
Old Jul 15, 2003 | 12:20 PM
MidNight_Sky's Avatar
Turn lighs
I change my front turn lights back to yellow and know it doesn't work. Does anyone know what is wrong with it I tried to find the fuse for the turn lights, but there looks like there is no fuse for it. The weird things is that my rear blinkers and side markers are workin, but not the front blinkers. Can anyone help. Thanks
Old Jul 15, 2003 | 12:25 PM
jbj420's Avatar
You did plug them back into the housing correct?
Are the bulbs bad? (loose filimint inside)
Old Jul 15, 2003 | 12:26 PM
uranium9v's Avatar
when you turn them on, do they blink fast? If so that means one of them, or the fuse, is blown. If the blink rate is normal could be something electrical. Make sure you have them pushed in all the way and the contacts from the bulb touch the harness contact.
Old Jul 15, 2003 | 09:10 PM
thats for the info. , but i figure it out. The connection in side the outlet was not connecting to the bulb. but on last question....Where is the fuse for the blinkers??? or are cars don't have it at all.
