Who is actually running 80+ watt headlights?
Old Jul 22, 2003 | 12:21 PM
airlinevomitbag's Avatar
I stuck some purple 80/85 watts in my car and the headlights get rather warm, not burning hot but warm. There is like 500 people on 500 threads (I searched) saying do not run higher wattage bulbs, but have they actually run into a problem on the Lancer? No speculation or friend of a friend of a cousin horror stories here, I want to hear from folks that are actually running these bulbs on a Lancer over a long period of time.
Old Jul 22, 2003 | 01:02 PM
YellowOZ03's Avatar
i run a higher wattage bulb. i don't remember what but the headlight cover is very warm if i have had them on for a long time. the only thing i have had a problem with is washing the engine bay and moisture getting into the socket and it shorts out the socket and burns it. i found a product by crc it is a dielectric grease that fixs that problem
Old Jul 28, 2003 | 08:45 AM
KTRLancer02's Avatar
I ran a higher wattage for about...7 months, until one of the lights blew out (it was its time to go) anyhow, i got some lower wattage bulbs after i read something about higher ones causing damage. But i didnt have any problems with the last ones.
Old Jul 28, 2003 | 09:00 AM
cerfur's Avatar
i know a few people who have run higher watage bulbs and burner the wiring harness but if this dose happen just buy some of those "heavy duty" wiring harness and u be all set
Old Jul 28, 2003 | 09:13 AM
uranium9v's Avatar
I run 80/100 in the headlight part and a 100w fog light bulb in the old turn signal spot and moved the turn signal to the old parking light spot. I changed out all the wiring so I won't blow any more bulbs....I musta blew about 5 or 6 before getting smart and upgrading the harness.
Old Jul 28, 2003 | 09:32 AM
that sounds like to much work. Especially when i know that everyone is too lazy to upgrade my harnesses
Old Jul 28, 2003 | 09:36 AM
uranium9v's Avatar
looks sweet though ...those front facing turn signals just look better suited for a second set of headlights.
Old Jul 28, 2003 | 09:38 AM
psionic98's Avatar
hey uranium, what kinda socket did you use for that, or did you actually find 100w 1156?
Old Jul 28, 2003 | 09:54 AM
uranium9v's Avatar
for the old turn signals??? I actually did a complete custom job on them....Used old plug and modified it to fit the new bulbs....
