Shaking on takeoff in 1st...
Old Jan 11, 2008 | 09:45 AM
cfdfireman1's Avatar
clean the clutch
Originally Posted by Domanni82
what do you mean.....? It happened when it was warm the other day for the first time as it says in my first post...
slide it a bit to get it heated up some but don't go nuts and smoke it.
Old Jan 11, 2008 | 09:59 AM
LancerPride's Avatar
it anit the clutch i already tryed what your talking about its the injectors im sure o and can you run with a bad injector??????
Old Jan 11, 2008 | 07:43 PM
Domanni82's Avatar
So you mean Let the clutch slide aka. let it slip and not let it engage?
Old Jan 12, 2008 | 10:16 AM
From what you described it could be either clutch chatter or an engine problem. Does it shake as you let out the clutch or once the clutch is all the way out? But because you say it only happens in 1st it sounds like a clutch problem to me.
Old Jan 12, 2008 | 05:56 PM
mine is when the clutch is all the way out and when im giving the car some gas
Old Jan 12, 2008 | 05:57 PM
Domanni82's Avatar
It's as I'm letting it out... would it not "chatter" as soon as it warms up like it does now?
I just got finished changing the tranny fluid, holy cow it was dirty....
I'd say never been changed considering I bought it when it had 48,000 or so miles, cant remember... but anywho, I'm goin to go out tomarrow driving it around as soon as the wifey gets home to watch the baby, so ill holler at yall then and tell yall bout it.
Old Jan 12, 2008 | 09:32 PM
Sounds like it's an after market clutch and yes some work better with a little heat in them. There very well could be some contamination on it as well and burning some of that off may help it, but if it doesn't slip and you can live with it I would just leave it alone.
Old Jan 13, 2008 | 09:42 AM
Domanni82's Avatar
kewl, thanks for the info, im pretty sure its not an aftermarket clutch considdering it only has 60000 miles on it. But how do i burn it off, i cant make my cluch slip....lol...I guess i have driven a manual for so long i for got how....
Old Jan 13, 2008 | 02:44 PM
start in second gear once or twice, it'll slip. with 60,000 miles it's most likely on it's third clutch.
Old Jan 13, 2008 | 03:12 PM
Domanni82's Avatar
ROflmao, what are you talking about.........How on earth could you say "on its third clutch with 60000 miles? A clutch under normal wear will last 100,000 miles easy. I have put 160,000 miles on a clutch, and used it pretty heavily.
Anyways, now that we got that outta the way.
Changed tanny fluid, drove aroud all day today, an nothing...Woot, hopfully that took care of it. Never did I feel a stutter, jerk, sputter, shake, nothing. So lets keep our fingers crossed that that was it.
Thank you all for your help. And no offense fireman, just can't see "third cluch" not till like 400,000 miles and ill never make it there.
Old Jan 13, 2008 | 10:18 PM
Sorry I was thinking Evo. oops
Old Jan 14, 2008 | 03:03 PM
mcgarvey's Avatar
I don't care what kind of car it is-- Three clutches in 60,000 miles means someone can't drive!
Anyway, from what he describes, it's an engine issue, and occurs when the engine is under load with the clutch fully engaged.
Are any codes present?
Old Jan 14, 2008 | 03:12 PM
Domanni82's Avatar
Nope, no codes. And it's when im letting the slutch out, not under a full load. I changed the tranny fluid, it has gotten better. But i can still feel a slight studder, but not like before. Any comments?
Old Jan 14, 2008 | 07:10 PM
mcgarvey glad you spent the time to read. 20K for an evo clutch is about average for most people that do autocross and track days.
Old Jan 14, 2008 | 10:44 PM
Noe18's Avatar
i think shes nervous, u know how virgins get lol jk
