Shaking on takeoff in 1st...
Old Jan 10, 2008 | 07:29 AM
Domanni82's Avatar
Question Shaking on takeoff in 1st...
Hia all,
So this has been happening for a while now. I have tried to narrow it down myself, but it has come to asking around, "Yes, I am a man." LOL
I have a 03 OZ 5 speed, and this mainly happens first thing in the morning. I live in SoCal so its not tthat cold ihn the morning, but when I first crank it up, even if I let it warm up a lil it will jerk franticly on takeoff, and only in first gear, once in second it doesnt. Once i get to the stropsign at the end of the street, it happens again, usually a few more stop signs till i get to the highway.
But now this is the kicker. Some people were telling me that my car was just cold natured and to let it warm-up a little more B4 taking off. But it finally happened for the first time on the way home last night when i was almost home. I was at regular opperating temp after about 20 mi. of driving.
Is it possible that the trany fluid/filter needs to be changed? I bought this car with 52,000 miles on it and have cleaned the IAC and throttle body very well just to clean up the idle and for better response, but since what happed last night I'm starting to think the tranny fluid and filter have possibly not been changed.
Gimme all you got guys. I just got my magnaflow exaust put on, so im all exited, but this is drivin me nutz.
Let me know if I need to elaberate more.
Thank You all,
Ryan
Old Jan 10, 2008 | 07:44 AM
LancerPride's Avatar
i have the same problem i cant fig it out ether but mine jerks really bad i think it has somthing to do with spark plugs geting mine changed soon
Old Jan 10, 2008 | 09:59 AM
SLVROZ_03's Avatar
The thing with buying used cars is that you'll soon find everything that is "wrong" with it. First thing I did with my recent acquistion of a '95 Civic is replace everything! Fuel filter, plugs, oil, trans fluid, etc etc...if you haven't already, do a good tune-up on it. Definitely check the trans fluid level, auto right?
Good luck!
Old Jan 10, 2008 | 12:21 PM
its 5 speed SLVROZ DO YOU READ GOD
Lol JK
Old Jan 10, 2008 | 04:09 PM
SLVROZ_03's Avatar
He Said Tranny Filter, God!
Old Jan 10, 2008 | 05:02 PM
Domanni82's Avatar
LOL, cant beat the personalities on this site with a stick...LOL
But yes, I have done plugz oil etc, but have not done the wires and tranny fluid. I wouldn't think that the wires would be the reason, would it? With the given simptoms i wouldnt think so?? thanks for the info, any other suggestions?
Old Jan 10, 2008 | 05:09 PM
The Drizzle's Avatar
I had something similar happen with another car I had and it ended being a bad fuel injector which really sucked because it happened 3 days after I got it and wasn't a cheap fix
Old Jan 10, 2008 | 05:11 PM
yeah one of my fuel injectors are going bad its ticking
Old Jan 10, 2008 | 05:21 PM
Domanni82's Avatar
but remember, this is mainly when the engine is cold and only starting off in first gear...
Old Jan 10, 2008 | 06:25 PM
mine start as first gear then start to happen in second and i just rember it happen like 3 months after geting a new clutch put in
Old Jan 10, 2008 | 07:28 PM
SLVROZ_03's Avatar
Start with a trans flush...
Old Jan 10, 2008 | 08:42 PM
Domanni82's Avatar
So it's 2.3 qts. of 75-90w right? What do yall think about mobil one or royal purple synthetic?
WEird thing is, Mobil one is 10.99 and the Royal Purple is only 8.99. Whats up w/ that? I would figure the Royal Purp. would be more...
And are there anymore ideas on the possible problem.
Old Jan 10, 2008 | 09:07 PM
cfdfireman1's Avatar
sounds like the clutch, try getting it warm once of twice to clean it off.
Old Jan 11, 2008 | 06:54 AM
Domanni82's Avatar
what do you mean.....? It happened when it was warm the other day for the first time as it says in my first post...
Old Jan 11, 2008 | 08:09 AM
i think its the injectors im replacing mine soon if you dont do it befor me and it fixs the problem i let you no have you tryed fuel system cleaning stuff
i tryed some and it worked for a lil bit but then the shaking came back its more like a sturter then anything
