oil leak on a 2002...
Old Aug 17, 2008 | 12:55 PM
bigblueqc's Avatar
Exclamation oil leak on a 2002...
OK new to these forums but i figure it cant help to get some opinions. I just got an 02 lancer from my brother when he joined the army and got shipped to germany, now however im finding problems with the thing left and right, already replaced front and rear motor mount, changed the valve cover gasket and i replaced the alternator and timing belt. Terrible for a 6 year old car in my opinion especially when the parts cost big money. Now, i have an oil leak from hell i cant find its from the back of the motor and its getting a bit on the lower half of the intake, getting on my alternator wires and obviously dripping down to the lower part of the engine, basically its on the rear passenger side.
What are common leak spots for these cars? first it was the valve cover and i changed that and it hasnt leaked since but this new leak is pissin me off ive never had this much trouble but then again i normally work on my thirdgen which has much more room to navigate and not transverse setups that c\are packed in lol
Thanks for any help
Old Aug 17, 2008 | 01:12 PM
EVOIXMR8916's Avatar
idk man either but im having a leak also from my 25k evo from the back of the block (flywheel side) and last oil change there was only 2.8 quarts in the engine!?!? luckily it was amsoil so i have no worry on engine internal damage.... but yea oil leak pros....HELP US OUT!!!
Old Aug 17, 2008 | 01:43 PM
lancer2show's Avatar
oil leaks are a pain. im glad i dont get them anymore.
Old Aug 17, 2008 | 11:03 PM
bigblueqc's Avatar
k....how did you stop getting them? Im not gonna just throw gaskets at this thing til i hit the right spot so anyone know whats up?? i looked at the rear of my motor and its everywhere on the left, so i dont know if its like a sheeting leak from up top rolling down or what
Old Aug 18, 2008 | 08:43 AM
atilla's Avatar
are you sure that the new valve cover gasket isn't leaking?
when my friend replaced his he had all sorts of trouble with the thing. ended up making his own gasket and slathering RTV all over the outside. worked like a charm.
double check the gasket and make sure that it's not leaking since it was one of the things you changed.
Old Aug 19, 2008 | 12:12 AM
bigblueqc's Avatar
positive its not the valve cover, the rear is clean from the valve cover down to where the intake bolts up so im guessin its elsewhere
Old Aug 19, 2008 | 03:58 PM
take pix of the leak. i was referring as in leaks in general. i have a lot of risk factors but they stopped.
4g64t_dohc
35
Sep 8, 2021 07:16 AM
Seansan
Mar 27, 2016 06:26 PM
VtexGt3
Sep 8, 2014 02:48 PM
def1
13
Jan 25, 2009 12:53 PM
Lumpy
20
Dec 18, 2007 02:19 PM
