lights gone out
Old Oct 11, 2008 | 10:57 PM
PhantomFreak's Avatar
lights gone out
my climate control automatic gear and lighter lights all went out are these all on the same fuse? i didnt try to use the lighter but i asume it dosent work one of my other fuses blew out but we already replaced that i would look but i have no idea what fuse this would be or even if its a fuse problem so if any one knows please help and if it is a fuse what number would it be
2003 lancer es
Old Oct 12, 2008 | 07:45 PM
no ideas? the lighter does work cant figure out these 2 sets of lights though -.-
Old Oct 14, 2008 | 08:13 PM
no one knows?
Old Oct 14, 2008 | 10:21 PM
Lucas03ES's Avatar
Did they all cut out at once? Did you check both fuse boxes?
Old Oct 15, 2008 | 04:23 PM
Juan Martinez's Avatar
Yes, check both fuse boxes, under the dash an in the engine bay. Its probably in the engine bay. It will more than likely be a fuse you wouldn't think it would be.
Old Oct 19, 2008 | 07:25 AM
the right back taillight isnt lighting either the break light is working the tail light is not i changed teh bulb
this is realy starting to anger me i took out evert fuse by hand and inspected them none are broken is there a 3rd fuse box?
Old Oct 19, 2008 | 07:28 AM
lancer2show's Avatar
i had this same prob at 1 point. 1 of the bulbs in my tail light were shot. you should check all the bulbs.
Old Oct 19, 2008 | 07:30 AM
replaced the taillight buld same problem
Old Oct 19, 2008 | 07:57 AM
some one said this could be from the draw from my amp is that possible?
Old Oct 19, 2008 | 10:27 AM
tried testing it wit ha voltage meter and im only geting 8 while the left side is geting 20 something i really have no idea what to do any idea where i could take this to get it fixed and how much
Old Oct 19, 2008 | 02:09 PM
It could be a grounding problem. I kept blowing fuses and bulbs when I found that one of my remote wires behind my cd player came loose. I also think it wasn't grounded right in the rear for my amp. Best thing to do is take out the sound system, check fuses and bulbs, and try everything out.
Old Oct 19, 2008 | 05:07 PM
that was my first idea tried ir redid the wires too regrounded etc etc we did mange to rig it up though spliced into the wire on the left side and ran it to the one on the right and it works so that means the plug is fine and wireing harness is fine so its the wire from the front being messed up somewhere.and atleast my light lights free fix > what ever a electric specialist charges
Old Oct 19, 2008 | 05:30 PM
There might be a wire pinched somewhere. Did you mess with any of the factory wiring when you put in your system?
Old Oct 19, 2008 | 06:21 PM
i thought of that and i wasnt on the right side of the car at all the lights run up the right side so i dont see how i would i messed it up i didnt even take off the wire covers when i installed my stuff all was ran up the left side
