No go from brembos
Old Mar 6, 2009 | 01:03 PM
MaD_CaNaBiCe's Avatar
meanwhile we are on this topic will 2g eclipse splines match up with the lancer splines for the rear or if not what splines with 5 lug spindles will?
Old Mar 7, 2009 | 09:18 AM
Juan Martinez's Avatar
Originally Posted by senate6268
Instead of having the spindles machined, the easier way would be to have a bracket made up to fit the Evo Brembo caliper to the Lancer caliper mount holes on the spindle. This is how the Wilwood BBK mounts the 4-piston caliper to the stock Lancer spindle.
There is one easier one, but twice as expensive. If you can get the Brembo GT caliper kit for the 2g eclipse, it comes with brackets, which they won't let me order unless I have a serial number, the kit bolts right up, at the price of almost 2 grand. We are still looking into some ideas on the hubs. We are looking into any information on the Outlander and 4g Eclipse and how their hubs mount and spline count.
Old Mar 9, 2009 | 11:24 AM
turbotime's Avatar
They are confirmed the same for the fronts by me... I would assume the rear would be the same.
If i remember correctly they are both 1" outer diameter with 32 splines.
This would technically mean you could do a 2g fwd swap into the lancer. may be a bit easier then going the evo route.
wbresson
Jul 9, 2022 06:21 PM
pukka
Jul 2, 2013 09:48 AM
k270kmh
Jul 7, 2011 03:21 AM
evo2809
May 2, 2011 02:02 PM
Evo3GEclipse
Jun 14, 2007 10:32 AM
