back light not working no matter what
Old Feb 22, 2009 | 09:28 PM
OldRiver05ES's Avatar
Well my tail light doesnt work (in the running position) i lights up fine when i break. Its only the smaller bulb that doesnt light up. Ok so text book awnser: the light bulb or the fuse right? replaced the fuse which was burnt but still no light. Swapped the bulb from the left one (right side is the one with the prob) into the right one still no light. Second text book awnser: the wiring is loose. Result: its not. So what could be the deal? any one with similar problems?/awnsers?
Old Feb 22, 2009 | 10:14 PM
lilazn64's Avatar
check it with multimeter. Bad wire/disconnected wire somewhere
Old Feb 23, 2009 | 11:05 AM
Juan Martinez's Avatar
I had a similar problem, but it was the bulb. If you get voltage to the connecter, its not connecting to the bulb.
