service engine soon light
Old Dec 21, 2009 | 11:18 AM
empiredreams's Avatar
Question service engine soon light
so i have a 03 lancer es 83,000miles. my service engine soon light came on. i went to pull the error code P0135/ H02S11. what is that what should i change or fix. they said its the o2 sensor in the engine bay on the exhaust manifold. any help or experience with this is really appreciated thanks.
Old Dec 21, 2009 | 11:36 AM
03lances's Avatar
I would first unhook the battery for about 10 mins which will reset the light. Now if it comes back on with the same code you probably will need to buy a new 02 sensor
Old Jan 26, 2010 | 12:42 AM
thedarwintheory's Avatar
ebay buddy cheap 02 censor if needed
Old May 6, 2010 | 07:24 PM
Meaner's Avatar
I just had the same problem.
With research i found out it was the pre-cat o2 sensor..
Just put it in today... bought a universal Bosch sensor...did some splicing and installed. im POSITIVE i did it correctly... all wires hooked up as per the online instruactions manual from Bosch.
Engine light back on the 2nd time I turned my car on prior.
please help!
Old May 6, 2010 | 07:30 PM
slatermvp's Avatar
did you reset the ecu? You will need to do that to clear the code or have someone clear it with an obd 11 scanner. I was cheap and used the RRM CEL eliminator to pass emissions.
Old May 6, 2010 | 07:36 PM
JRR's Avatar
JRR
all that a p0135 code is, is a heated o2 sensor circuit that the car isnt seeing.i ran my car like that with that code for over a year before i did some changes and put it back in.
josh
Old May 6, 2010 | 08:16 PM
Meaner's Avatar
Yes, ECU was cleared. Im assuming reason why light came on 2nd time i started it up (about 45mins after the install).
I need to fix this in order for my vehicle to pass air care
P0135. possibly the actual heat sensor?
Old May 7, 2010 | 03:15 PM
Meaner's Avatar
http://www.boschautoparts.com/Techni...allGDWEB09.pdf
i used "type B" because that was the only one with the "blue" wire.
Old Jun 4, 2010 | 07:28 PM
jwick76's Avatar
Having the same type of issue:
I'm having a code for my first o2 sensor that's giving me fits, it's throwing a P0134, which is "Ckt No Activity Detected, 1/1".
I replaced the sensor, and cleared the code, even reset the ECU, and this code has come back. Anyone have any ideas?
The original sender was fried from my Thermo-tec header wrap causing too much radiant heat, melted through the wiring. ANd in addition to the P0134, it threw a lean code,
which has not shown back up with the new sensor in place...
I've double-wrapped the sensor for the first 10" with thermotec wrap to block the heat, including the sensor after the nut (so only the nut is exposed).
The only thing I can think of is that when the original sensor fried, it took out something with it?
I'm hoping it's something simple and not a problem with the ECU... When i reset the ECU, it only stayed cleared for 7.9 miles.
When I reset the code it threw again within 2miles of driving...
Any help would be great.
Do you think it's because the thermo-tec wrap is making the header too hot and frying the sensor?
Old Jun 5, 2010 | 08:21 AM
jwick76's Avatar
Bump.
Old Jun 8, 2010 | 01:19 PM
jwick76's Avatar
alrighty, well, I'm going to rip off the thermo-tec and see if that solves the issue, hopefully i can reset it and the o2 sensor isn't completely fried. I'll post any results in here in case anyone else has the same issues
Old Jun 8, 2010 | 01:35 PM
eusgen's Avatar
Having similar issues, has this problem caused your catalytic converter to go bad? I think the car running lean causes this correct? I need help. My cat is rattling like its hitting the ground.
Old Jun 9, 2010 | 10:21 AM
blaze_125's Avatar
Change it?
Old Jun 9, 2010 | 10:41 AM
eusgen's Avatar
Originally Posted by blaze_125
Change it?
Ok, I plan on it, but its the second one im going to have to change, im trying to figure out whats causing it to break. thanks
Old Jun 9, 2010 | 08:28 PM
jwick76's Avatar
how old is your car? the second one almost rotted off of mine within 7 years. this is the first o2 sensor I'm having issues with. I'm returning it tomorrow, getting another one and we'll see if the thermo-tec wrap was the culprit. I guess you can individually wrap the header pipes, but doing the blanket wrap too thick causes too much of a heat trap,...AND i guess that o2 sensors have a melting point for the wiring...
