RRM Header Mesh Leaking
Old Mar 24, 2010 | 09:01 AM
EngRWW33's Avatar
Originally Posted by s21197
what does a stock lancer use? is there a flex section or not? cause if there isnt, then why would an aftermarket header need one?
Spring loaded bolts.
Old Mar 24, 2010 | 09:03 AM
evo_soul's Avatar
Originally Posted by Nathan0490
RRM refused to warranty my V1 because they said the manufacturer was out of business. I was offered only 10% off the purchase of a V2, basically telling me $400 went down the toilet. I'm no longer impressed with them.
if its leaking from the flex pipe, get a repair job done and replace the flex pipe. There is nothing wrong with your 4-1 piping from the manifold. just replace what needs to be done. do your research and find the flex pipe you need and go to a good welder.
This week I am meeting with two shops to see if I can get a dampening kit manufacturered here in north america to compliment header upgrades.
Old Mar 24, 2010 | 03:20 PM
Nathan0490's Avatar
I went to a master welder he looked inside it and it had gone inside out. The same thing happened on the first one that they replaced before the manufacturer went out of business. There was no way to fix it. If you have seen one of these go you would understand that there is no way to bend it back after it gets as bad as it was. He ended up cutting the flex portion out and custom fitting a solid piece where it had been. This fixed my exhaust leak but it also causes added vibration to the vehicle.. the alternatives were to go back to stock or pay RRM another $400 for a product that may or may not hold up.
