High-pitch Side window noises&&rattling on snow
Old Feb 25, 2010 | 10:37 PM
sixthmatrix's Avatar
Hi,
I am an owner of 2009 Lancer GTS M/T.
I bought my car on 2009 June, and everything works great except very few problems.
Problem#1
My side windows.... make high-pitch noises when I pull it down or up. All 4 of them.
Especially after raining or snowing. It also seems to make verticle scratches to the window which is one of the common known problems in the lancer, but I did not able to find anyone arguing with extreme terrible noise the side windows make when it goes up or down.
It does not always happen, but most likely after raining or snowing.
What I am guessing is that, the rubber at the bottom of the side windows is tightening the windows too much..
I was wondering if moleskin would fix this problem..
http://www.tintprotector.com/mitsubishi/evolutionm.htm
Beforehand, do you think if I bring the car to the dealer ship, they will take care of it under warranty??
I guess I can buy the moleskin and do the job, but I just want to make sure..and if dealership does everything for me that would be nice for me.
Problem#2
My car, when I turn left or right on snow very slowly(5~10mile/h) it rattles so much,(i mean,..seriously..) especially the front half part of the vehicle. I personally think its either a problem within the suspension, or my stock tires, which are only 6k miles old. This rattling does not happen when there is no snow at all. It is easier to think my car won't turn left or right smooth on snow when it goes slow... It goes straight fine on snow, but kinda slippery.
Are above two problems quite rare? Because of these problems, when I am in my car with other friends, I am afriad to pull down the window due to the noise, or drive above snow and turn due to the rattling.
By the way.. my car is stock.
Old Feb 26, 2010 | 05:02 AM
kalpakiotis's Avatar
The window problem sounds like the tracks could use some grease. In wet weather there is a lot more humidity which could cause the squealing.
As for the shuddering in the snow, I have never noticed anything like that, but my guess would be if you have traction control it has something to do with that.
Old Mar 27, 2010 | 11:06 PM
Is it possible that the shuddering in the snow happens due to the problem with anti sway bar OR tires??
I am using stock tires but I am thinking of replacing them.
Old Mar 28, 2010 | 10:31 AM
s21197's Avatar
no idea what the shuddering is, but moleskin wont do anything its garbage
Old Mar 30, 2010 | 03:47 PM
CamShaft's Avatar
With the shuddering in the snow, the only thing I can think of would be the tires loosing grip while turning giving you some tire hop potentially. If this does happen on dry or wet roads I wouldn't worry too much. I believe it is a traction problem causing this.
As for the windows, the dealer should fix this by installing new window track or something of the sort, that doesn't seem normal at all. Every dealership is different, give them a call and see what they suggest, also try calling a few dealerships
MISHI
20
Sep 6, 2013 06:43 PM
Bradley_J
Nov 29, 2012 11:42 AM
Cablazn
Aug 20, 2009 10:55 AM
kikiboi
11
Jul 20, 2008 03:11 PM
mmartahus
Apr 16, 2008 07:03 PM
