Sponsored by:
Sponsored by: CARiD
Window Rattle?
Old May 31, 2009 | 04:04 PM
Cablazn's Avatar
Window Rattle?
So I am not sure if anyone else has had this problem yet, but I noticed that while I am driving (more noticeable when there is music/bumps or any other type of vibration in the door) the front driver side window rattles. It sounds almost as if it is going to shatter. If you tap the window, it makes the same sound as well. A friend of mine said that it probably is not tempered properly... any ideas?
Planning on taking it to the dealership soon... hopefully they wont void for tinted windows lol.
Old May 31, 2009 | 04:34 PM
chriswolf81's Avatar
they removed at least part of your rubber trim, so the tint wont scratch. it only rattles when half or fully open not when closed.
Old May 31, 2009 | 05:25 PM
plip630's Avatar
bring your car first where you get your windows tinted so they can check everything is in proper place before going to the dealer
Old May 31, 2009 | 07:14 PM
iamblue03's Avatar
I had exactly the same problem with my front driver's door window. I drove to dealership for an oil change and also had the problem taken care of. It was a minor problem of a pin went loose and the problem was fixed in less than 30 minutes. I was surprised when the service manager told me that "it is the japanese quality."
Old May 31, 2009 | 10:44 PM
Cablazn's Avatar
I think you are right about that. It doesn't seem like its the tint or anything like that because then this problem would be on both sides. I will have them take a look at that soon (or maybe I'll do it myself). Thanks for the help!
Old Aug 19, 2009 | 03:26 PM
shyong's Avatar
OP, did you ever get this issue taken care of? I'm having the same issues as well but rather take care of the problem myself.
Old Aug 20, 2009 | 09:29 AM
Hen5000's Avatar
i had the same issue and took it to the dealer. They fixed it and said the bracket holding the window was broken and they had one in stock and replaced it same day for me. although if i leave the window open in a small crack and drive i hear a little rattle, but hey it's better than before... lol
Old Aug 20, 2009 | 10:12 AM
ZeroFighter83's Avatar
Wasn't there a TSB posted by RussellM stating it was a loose nut inside the door card or something? I'm going to try and find that post.
Old Aug 20, 2009 | 10:32 AM
shyong's Avatar
yeah, if you can hunt the tsb down I'd appreciate it. I tried searching for it myself but I failed. lol
Old Aug 20, 2009 | 10:45 AM
Noize's Avatar
EvoM Administrator
Originally Posted by RussellM
TSB-09-42A-004 Rattle from Doors. Loose Window Bolts - 08-09 Lancer, EVO X, SPORTBACK
My car does this, need to fix. HUGE annoyance.
Old Aug 20, 2009 | 10:55 AM
shyong's Avatar
thanks for the tsb, noize
Turbo_Saloon
Dec 14, 2012 10:21 AM
titleistforged
Dec 13, 2012 10:02 AM
DMuhny
Lancer Troubleshooting
11
Jun 23, 2011 10:13 PM
Maverick158
Oct 26, 2010 07:29 AM
natenet
14
Jun 8, 2005 09:53 PM
