speaker rattle - FIXED!
Old Jun 6, 2005 | 05:13 PM
natenet's Avatar
Lightbulb speaker rattle - FIXED!
just got my RA (with s&s) last thursday - since i picked it up, the passenger door rattled with any positive settings on the the bass controls - after looking around on the forums i determined that it was the window controls causing the rattle
steps i took to fix the rattle:
1. pry up the window control panel - easy on passenger side - a little tougher on drivers side
2. disconnect wiring hareness(es)
3. wrap small strips of duct tape around each tab that holds in the control panel - duct tape is ghetto, but it serves it's purpose especially when its not visible - the rattling was comming from the panel's contact with the rest of the door
4. re-connect wiring hareness(es)
5. reinsert panel into the door - considerably more resistance in puting it back in than taking it out - from the duct tape
sound is MUCH improved - no rattling at all even with bass setting 4+
if anyone needs pictures to explain - let me know
nate
Old Jun 6, 2005 | 08:49 PM
Sportback79's Avatar
Hmm..thanks for the heads up. I've been hearing this rattle from my passenger door since new and was wondering where it comes from. Since pulling on the door pull stops the rattle, it would make sense that it's coming from the window control panel. I'll have to give your idea a try.
Old Jun 6, 2005 | 11:17 PM
captain150's Avatar
nate
Pics would be nice I've known it was those little covers almost right when I first noticed it, I just don't know how to get em out. Just pry?
Old Jun 7, 2005 | 06:51 AM
BassTek's Avatar
I've been starting to hear a rattle from my passenger's side as well. I wonder if this could be the problem.
Old Jun 7, 2005 | 06:57 AM
otter's Avatar
EvoM Administrator
Yup, they'll pop out pretty easily.
Old Jun 7, 2005 | 08:41 AM
Walbomb's Avatar
Good to know because that sound has been driving me crazy and I haven't been able to find where exactly it's coming from. I'll have to try to fix this when I'm taking my dash apart to put in the new lighting kit I got off Z Lancer Man.
Old Jun 7, 2005 | 09:10 AM
natenet's Avatar
pics - update
pics are attached - pretty simple fix - 10 minutes max
after further listening - this does not completly eliminate the rattle, but it is greatly reduced - even with the control panel detached from the door something inside the door is still rattling very slightly
after taping - with bass 4 treb 2 bal 0 fad r1 - the rattle is almost never audible - even on very bass heavy songs
before taping - my rattling was very severe (even with bass at 2) and this is a huge improvement
one thing to note - in order to stop the rattle you have to put enough duct tape on the tabs that the panel is substantially more tough to pop back in
i believe the problem is that the panel (wo/ tape) is not pushing hard enough(horizontally) on the side of the door panel it sits in - with the right amount of duct tape the two panels are then more firmly attached to each other
also - make sure the last piece of tape you put on goes vertically from the bottom-over the top-and back down to the bottom - that way the door panel won't push the tape down to the bottom of the tab
nate
Attached Thumbnails speaker rattle - FIXED!-rat1.jpg   speaker rattle - FIXED!-rat2.jpg   speaker rattle - FIXED!-rat3.jpg   speaker rattle - FIXED!-rat4.jpg
Old Jun 7, 2005 | 12:59 PM
bruce988jl's Avatar
Someone should take the last post and make it into a How-to sticky. Good work Nate, i think everyone with a RA or lancer in general could use this
Old Jun 7, 2005 | 06:37 PM
captain150's Avatar
I just did this today, I used electrical tape. It's really easy. The driver's wires are kinda stuck between insulation and the door panel, so you have to pull up on the driver's panel before you can disconnect the harness. The rattles are pretty much gone. Volume at 30, bass at +6, treble at -2 with S&S and there is basically no rattle. The door grab handles rattle a little bit and the trim around the door opening handles rattles a little bit. But it's so little that you can hardly notice it.
Old Jun 8, 2005 | 01:17 PM
Volkmann's Avatar
Hmmmm I have no rattles at all. My 2002 Lancer OZ had a rattle in the drivers side "A" pillar that drove me friggin nuts!!!!! I would knock the crap out of it trying to silence the noise.
Old Jun 8, 2005 | 04:19 PM
otter's Avatar
EvoM Administrator
My rear deck rattles and my headliner rattles just above the driver's visor. Grr. Gotta get that fixed.
Old Jun 8, 2005 | 04:34 PM
N1te's Avatar
did you just take the control off or the whole door? If you took the whole door off can you post pics?
Old Jun 8, 2005 | 05:35 PM
natenet's Avatar
just the window controls - take a look at the first picture - just pry the control panel up gently with your fingernails - it should pop right out - it is only held on with tabs - no need to take apart the whole door
Old Jun 8, 2005 | 07:42 PM
ikeing's Avatar
i have the same problem and a american used a canadian problem solver duct tape (red green show) to fix it . i am going to try this!
Old Jun 8, 2005 | 09:53 PM
sobe's Avatar
I have never experienced the rattling because I never have my music over 15, but I should give this a try just for the hellevit.
You know... in case I DO decide to be a rebel and turn it up.
migs647
Evo X How Tos / Installations
202
Sep 16, 2020 02:25 PM
vszutu
Toronto Lancer Club
Mar 15, 2013 05:09 AM
bigd31388
33
Aug 20, 2012 07:59 AM
boobcakes
55
Dec 19, 2011 10:05 PM
vassili
Jan 23, 2010 10:49 PM
