HELP! Problem With Fuel Pressure
Old Feb 24, 2010 | 06:30 PM
oZuser's Avatar
Hi guys, i need ur help here. I have a 2002 lancer oz rally and i swap the engine from an 2006 lancer es. After swap my fuel pump start screaming and when i drive it its like there not enough fuel in the cylinders(it shaking). I made some research and realized that on my old 02 engine the fuel pressure regulator was build on the engine, but the 06 engine dont have it build in, the fuel pressure regulator on 2006 lancer es its on the fuel pump assembly,in the tank. Soo basically my car right now is running without a fuel pressure regulator . I tried to change the fuel pump assembly and tank from 2006,but is not interchangeable with my 2002 lancer.
guys please i need to know if i can build on my new engine a vacuum operated fuel pressure regulator or i need an after-market hight performance fuel system. Please i need ur ideas here.
I need to know if someone had problem like mine.
Old Feb 24, 2010 | 06:37 PM
Demon_ni2's Avatar
the 06 has a non-return fuel system, extra doesnt keep circulating to and from the tank..
if u swapped the motor into your 02.. then u still have your return line to the fuel tank..
u need to pull your fuel rail and fpr off your origonal motor, and connect the return line again on the 06 motor..
most all the motors ive used int he past were all off 04-06 lancers, i have never had a problem, but this was one of the things i swapped over from my older motors. u probably have a few nasty bubbles int he fuel lines, the return line should correct your problem.
Old Feb 25, 2010 | 09:46 AM
oZuser's Avatar
thx for answering, but u sure %100 that i can fit the fuel rail on 06 engine?
Old Feb 25, 2010 | 11:36 AM
Jehuty's Avatar
why not try it...and then if it doesn't fit take it off and let us know. Better you take the advice then second guessing.
Old Feb 25, 2010 | 05:55 PM
senate6268's Avatar
Yes the fuel rail will fit. It is still a 4G94 engine. The 02-03 4G94 and 04-06 4G94 engines differed only in their fuel systems (and cosmetically with the body).
Old Apr 23, 2010 | 08:22 AM
oZuser's Avatar
didn`t fit folks, i have to modified the rail
Clipse3GT
44
Jan 29, 2022 09:54 PM
Moronicicon
Lancer Engine Management / Tuning Forums
Jun 29, 2017 10:15 PM
Salman Hashmi
Lancer Engine Tech
Mar 13, 2016 12:01 PM
araz5260
15
Jan 7, 2016 03:37 PM
KevinD
Dec 9, 2010 08:16 AM
