2003 Lancer ES Intense Rattling When Stopped (Automatic)
Old Mar 17, 2010 | 08:06 PM
Braydo25's Avatar
Hey guys, I have a 2003 Mitsubishi Lancer ES, for the past few months I've notice the motor and or trans of my lancer has been rattling minorly, but recently it started to get REALLY BAD. My Lancer has an automatic transmission. When I stop at a light or stop sign, the front end of my car begins to rattle SUPER bad now, the whole car begins to shake and there is a very loud rattling noise. It will rattle for as long as I am stopped and in "D" (Drive), if I throw the car into neutral at a stop when the noise/rattling is happening, the noise/rattling COMPLETELY stops, and th car acts normal again.
The car drive absolutely great, no problems going through all the gears, transmission very very rarely slips (It's happened once, but the car was cold and I was getting onto the freeway)
I'm leaning towards the motor mounts of my lancer as the culprit for the rattling. Since it only happens when the motor is engaged to the trans and power is going to the wheels, there is torque on the motor in D, so it rattles on the bad mounts. When the car is in N, it does not rattle because there is no torque on the motor since it is not working to spin the car's wheels.
I may be wrong, it may not be the motor mounts. Has anyone with a 2003 lancer es ever had this problem? I would hope someone who has experienced and resolved the same thing is part of the evolutionm community and could help me out.
Thanks!
Old Mar 18, 2010 | 12:02 AM
turbolancer02's Avatar
check the flywheel to torque convert. bolts , also check the front crossmember that runs underneath the car especially at the front radiator support where it bolts...unfortunetly its common for that to rust putting pressure on the other mounts ...My 2002 has 135k on it with stock mounts and no issues
Old Mar 31, 2010 | 07:56 AM
shutout809's Avatar
my gf's golf did this once.... it would vibrate alot when stopped... it turned out being a spark plug and ignition coil maybe thats it?
Old Mar 31, 2010 | 12:39 PM
cedes14bamg's Avatar
haha on my 03 it would sooo rattle but it was the dam grill that was cracked at a spot so the engine torque would make it rattle
Old May 5, 2015 | 07:45 PM
artezt's Avatar
Same issue with wife's ES
Exactly the same issue with my wife's 2003 ES. Did you ever figure out what the issues was?
Thanks!
Old Aug 15, 2015 | 07:54 PM
sxperia101's Avatar
Bought a 2002 lancer gdi engine in April, been busy havent got a around to get it fully ready. The previous owner havent drove it in years. what are the parts i should change???? oh i noticed that whenever i get to 2000rpm or higher the gdi eco comes off
parralegend
Oct 10, 2014 12:45 PM
Llew
Sep 6, 2013 01:09 PM
campbmic
22
Mar 4, 2012 08:24 PM
NelloMorto
Dec 20, 2010 02:58 PM
Stingray_63oz
Lancer Troubleshooting
Feb 16, 2005 11:59 AM
