03 OZ not always starting
Old May 30, 2010 | 06:43 PM
senate6268's Avatar
Originally Posted by bowlofturtle
so i will be working out of intake box area to do the work? or should i go from under and behind the trans to pull it off.
picture is useless to me.
You'll need to remove the intake box and tubing that goes to the throttle body to gain access to the bolts. The starter will be removed from below the car after the bolts are removed and you disconnect the wiring from below.
Old May 31, 2010 | 04:22 PM
bowlofturtle's Avatar
sears offered me a starting charging battery test... would it be the same testing on the car and off the car the starter?
