Need Help to install RRM strut bar and exhaust.
Can anyone tell me how to install the strut bar and exhaust myself. I would like to do it myself, but I am not that mechanical. Is it easy?
Very. Undo a couple bolts, put em back on. Strut bar may take a little coercing to get on at first, but it slides on easily if you apply equall pressure to both sides. Try pushing from the middle. It takes more pressure, but it worked for me. You won't even need a lift to do the axle-back, but it would help if you could put your car on jack stands. Real easy though so long as your bolts aren't rusted tight.
There's a gasket most likely. I'm sure they'll mate just fine. Get on your back and take a look under if you can. It's really simple when you look at it. If you can turn a wrench then you can do both these mods.
