Wierd grinding or growling noise!
Okay, so recently my car just started to make a growling and almost a grinding when driving straight and even worst when making right turns, but never left turns. I check the passenger side tire/rims and i had a bent rim and worn out tires. So i got those replaced with new ones and it's still making the noise. I recently had my tierods replaced so it couldnt be that. I know my brakes are going bad but i doubt it could be the brakes. Help PLOZ!
ok so i jack up the car and move the tires up and down and left and right and dam it feel like it had a lot of play. but i did the same to the drivers side tires and there was barely any play so im assuming its the passenger side wheel bearings?
okay so i bought the bearings and took it to a local shop to get a quote on the price and he said 90 bucks ea side, because he has to take the bearings to get it press in somewhere else, and also said that its gonna take 6 hours! i was like wtf! 6 hours lol. Is that a reasonable price since the bearings were only 40 bucks ea
What shop works on a $30hr rate?
That's low, I'd do it in a heartbeat.
No it's not. It just takes a bit of time, like most other stuff.
Read the instructions ahead of time, plan accordingly, if you're missing tools, get them before you start, and plan how you're going to get that thing out of the hub and back in. If you don't have a shop press, befriend someone that does or get one cause you'll need one to get the job done.
