Lights Out
Old Oct 31, 2011 | 10:24 PM
mace1890's Avatar
Lights Out
My right tail light is out and my dashboard light for my speedometer, checked the bulbs and there fine dont know if its a fuse i looked and didnt see any of them burned out not sure what it is.
Old Nov 2, 2011 | 12:53 AM
mace1890's Avatar
i found a fuse that was out replaced it tried to turn my lights on and it blew the fuse again, i spliced in to the wire that went to the bulb and ran it to my battery and the light worked fine. im thinking now its making a bad connection some where, not sure where though. Still not sure why my dash light is out
Old Dec 13, 2011 | 03:47 PM
Bugz's Avatar
All I would suggest is to double check on your fuses, if they are all fine check whether your dash bulb has blown off and replace it and finally check the wiring.
Old Dec 13, 2011 | 04:05 PM
CrAnSwIcK's Avatar
if the fuse blows, it means the current rating for that circuit has been exceeded. Bad connection won't blow fuses, you have high current short.
Old Dec 13, 2011 | 04:13 PM
Vivid Racing's Avatar
This.
You've got a short. Check all your wiring from the fuse box to the tail light. Don't put a higher rated (bigger) fuse in or you risk starting a fire.
Old Dec 18, 2011 | 02:42 AM
madmike91's Avatar
I recently had the exact same problem. It happened right after I installed a new stereo unit. I kept blowing fuses so I pulled the radio out , replaced the fuse and it was fine. Just have no radio until I have time to figure the problem out
Old Dec 19, 2011 | 07:49 PM
mace1890's Avatar
i had a pinched wire under my center counsel it took me awhile to find it but its fine now
Old Dec 20, 2011 | 02:44 AM
madmike91's Avatar
Thanks that gives me somewhere to start with when I fix mine tomorrow
Old Dec 21, 2011 | 12:21 AM
mace1890's Avatar
yeah it can be anywhere it was my tail light out so i thought probably somewhere by it but it ended up being a pinched wire from putting my center counsel back together from previous work, hope you find it
