Headlight issue
Old Nov 16, 2011 | 02:53 PM
Sirlanceralot's Avatar
Question Headlight issue
so i recently purchased an 08 gts and my headlight bulbs have been flickering on and off, i took my bulbs out to see if the bulbs were shorting out but the entire spot where you connect the bulb to the connect is like melted??? has anyone witnessed this problem??
Old Nov 16, 2011 | 03:03 PM
Vivid Racing's Avatar
Aftermarket or stock headlight housings?
HID or halogen? If HID, is it factory or aftermarket? I'm not familiar w/ what options came on which trims on the Lancers.
Melting electrical components means heat, which usually means a short or a bad ground but if that were the case, the bulb should have blown out before anything melted.
Old Dec 25, 2011 | 08:44 PM
xdragonicx's Avatar
Are the halogen? If they are get a new set and put some thermal grease in the socket before you put them on. I've read/heard somewhere that it helps with the heat. I have no proof or evidence of this but I'm doing this and haven't had a problem so far.
Beardly P
Aug 30, 2012 09:34 AM
i.Apotheosis
Lancer Troubleshooting
Mar 27, 2012 07:07 AM
Evojj25
Dec 29, 2010 06:32 AM
ODUB
Aug 5, 2008 08:04 PM
