Stock bulbs
Old Mar 2, 2012 | 10:37 PM
i.Apotheosis's Avatar
Stock bulbs
I found this. Please delete if it is a repost. I was looking for turn signal bulb sizes, and got the py21w from the forums but I guess it is the same as 7507....I know nothing of bulbs lol I hope the HID setup to follow my new headlights and some aftermarket turn signal bulbs all work out...
http://www.modifiedlife.com/2002-mit...lb-size-guide/
High & Low Beam Headlamp Light Bulb Size: 9007
Parking Light Bulb Size: 194NA
Front Turn Signal Light Bulb Size: 7507 Or 2827
Rear Turn Signal Light Bulb Size: 7507
Tail Light Bulb Size: 7443
Stop Light Bulb Size: 7443
High Mount Stop Light Bulb Size: 7506
License Plate Light Bulb Size: 168
Back Up Light Bulb Size: 921
Front Side Marker Light Bulb Size: 194NA
Rear Sidemarker Light Bulb Size: 7443
Dome Light Bulb Size: DE3175
Trunk/Cargo Area Light Bulb Size: DE3022
Old Mar 3, 2012 | 12:44 AM
Ace King's Avatar
https://www.evolutionm.net/forums/la...ock-bulbs.html
what headlights did you get?
Old Mar 4, 2012 | 08:55 AM
thanks
I went with the ebay "black housing" stock looking headlights. The headlights have a cheaper plastic than OEM and there are small circles on the lens from the mold, but for 125 bucks they will do just fine, and definitely are better than my cloudy lenses. I did decide to get some clear silicone to line the joint just to make sure I wasn't going to get any water leaks/humidity in the housing.
IMO, the cedia projectors are cool, but I don't care for the side "feather" looking section where it is amber and I think three lights has a busy look. I always thought those early nineties civics with the jdm three-light headlights looked busy and cramped.
I am going with the silverstar discontinued bulbs (found on ebay) for the the turn signals. I had them on my 636 back in the day. They have a blue coating, so they reflect blue, but light up amber, and then I am going to go with the ddm 5k 35w hid setup, and I am considering getting the dual beam, but I am still researching there. Apparently the dual beam is one centimeter long, so I don't know if that means I have to modify the headlight housing or if they will fit fine without modification. I'll probably have to ask the boys here to figure that one out.
Old Mar 19, 2012 | 08:14 PM
OZR_Lancer's Avatar
might be a lil late but to clarify on this, the ones with the 3 light things you are refering to arent cedias btw...
the one u saw on ebay is the evo look type
evo style:
cedia: on these the inner light is the high beam [9005] and outer is [h1]
i act almost bought the blacked out ones back in 2008 but as soon as i saw the cedia's i just fell inlove with them, but i can understand the 3 light thing being cramped, but thy do look sexy
Old Mar 19, 2012 | 08:26 PM
Ace King's Avatar
I have those depo projector headlights. haven't installed them yet. was waiting for them winter to be over. have had some really nice weather as of late so it might be time!
Old Mar 27, 2012 | 07:07 AM
dbowdt's Avatar
I had to wait as well but i finally got them in! they look great! One thing is the passenger side rear or the assembly sticks out a bit, i have to see if i can figure out why.
Has anyone put DDM hid's in the Depos? What kit did you use if so? H7 or 9007?
Jake26
Lancer How Tos / Installations
107
Jan 17, 2018 06:57 PM
Jake26
Dec 3, 2015 09:12 AM
Evo8yu
Feb 18, 2013 08:37 PM
johentie
Jul 28, 2011 01:56 PM
Gambitincognito
14
Oct 25, 2010 07:18 PM
