Ac not blowing cold?
Old Jun 4, 2012 | 01:37 PM
lancer586's Avatar
My ac has recently stop blowing cold and i had the car since 60k miles, now its got 160k miles >.< ... I never had the car recharged yet so im assuming it needs ac recharge. When i turn on ac it just blows out cool air, but not cold like i need it to.. any suggestions?
Old Jun 4, 2012 | 01:58 PM
noob12's Avatar
I would say just recharge it but if you had your car for over 100k miles already, you might want to have your system check for leaks first.
Old Jun 4, 2012 | 02:51 PM
lancer586's Avatar
Also if the car is in park for a while, the ac tends to blow out hot air..
Old Jun 4, 2012 | 06:10 PM
pool playen bob's Avatar
this ^ by far. she's probably got a few pinholes where she leaked out over the years. only a couple pounds. but yeah it'll have to be sucked. pressurized inspected. pulled vacuum. then filled and maybe a little dye if no leak was found. and at that miles its very possible to have a leaking compressor.
a/c should work pretty much as soon as you hit the button. unless you've been running the heater for a few hours heat soaking everything. but even then 30 seconds or so you should notice cold air.
Photool
Lancer Troubleshooting
26
Jul 6, 2015 10:00 PM
lanport
24
Jun 20, 2015 06:03 PM
ralliart 04 21
Jul 29, 2013 11:36 AM
blakroyal
Dec 28, 2011 09:50 PM
rcheung
May 27, 2005 07:53 PM
