Info Screen/Display Problems
Old Apr 2, 2013 | 07:56 AM
azoutlaw480's Avatar
Just a few weeks ago I am noticing that there is progessive problem with the info/display box. I noticed a small LED break, like the LED is busted and looks like its leaking. Now it is spreading up towards the fuel area and is merging into the section that shows my gear/drive/reverse.
Has anyone had this issue? Not sure if this matters but I only noticed this after I installed a sprintbooster V2.
Car is an 08 GTS
Old May 10, 2013 | 06:35 AM
HatrixMouse's Avatar
Car is an 08 GTS
I'm pretty sure the SprintBooster shouldn't be a cause for that, unless it's actually throwing power back into the display guages and overcharging the LEDs (which I highly doubt).
Best guess is normal wear/tear? Are you still under warranty? If so, have it checked out. If not, see what a stealership can do (without charging you money!)
Old May 22, 2013 | 07:47 AM
I am the second owner and my warranty does not cover inside the cab electrical systems.
The "spiders" or "veins" have actully progressed up further and have mostly dissapeared. There are a couple small blotches still around the gear indicater section right near the middle. Ill have to take a pic cause its strange. Maybe Ill try disconnecting the booster for a bit, or just turn it off. I always run with it in the green.
Gh3ttoRoM3o
Oct 5, 2015 03:17 AM
jeffpinto
Mar 21, 2015 03:20 AM
4G63_EVO
Mar 11, 2014 03:49 AM
Labrie
Lancer Troubleshooting
Jan 18, 2012 05:27 PM
