Erratic speedometer 03 Lancer LS A/T
Old Oct 12, 2014 | 09:19 AM
Sir_Lancer_Lots's Avatar
My speedometer has been acting weird for the longest. Sometimes it will get stuck at 60 regardless of how fast or slow I'm going. I swapped out my input speed sensor with an aftermarket dorman speed sensor and it went back to normal for a few days... my trans even shifted smoother. Now it seems like it's gotten worse. Speedometer says I'm going 55-60 when I'm driving about 25-30. It'll only go past 60 when i hit 80 or more. No check engine light on the dash either, btw.
Old Oct 13, 2014 | 09:07 AM
CrAnSwIcK's Avatar
output speed sensor?
Old Oct 14, 2014 | 09:40 AM
Figured it would have to do with that. Might end up getting a oem input and output to be sure. Replace the aftermarket input while I'm at it.
Old Oct 20, 2014 | 01:05 PM
Thahomeboyb's Avatar
Finally , I have the same problem. I bought this piece offline. It says its an input plug.
I tried it in to places.
The first place (ontop of tranny underneath the intake box) kinda had to force it in the wiring harness and when I put it in the whole the scree holes didnt match.
The second place too the left and above the first spot . Seemed like it went into the engine. I kinda had to force it in the wiring harness again. It fit in the hole and the screw holes matched perfectly. So I screwed it in. I tried to start it , it wouldnt turn over. So I switched back to the old part , and it started fine.
Im not sure if they gave me the wrong part or I put it in the wrong place. Can you post a pic where the input and output sensors are.
Attached Thumbnails Erratic speedometer 03 Lancer LS A/T-forumrunner_20141020_155643.jpg
Old Oct 22, 2014 | 08:31 AM
bump.
Old Dec 17, 2014 | 07:22 AM
Terribly late response, but i swapped out my output speed sensor with an oem part and my shifting is much smoother. But my speedometer is still acting up. May end up replacing the aftermarket input with an oem input. I'll post a pic of the locations shortly.
Old Dec 17, 2014 | 11:47 PM
Yes please post pictures im really in need .
Old Nov 22, 2015 | 06:43 PM
Jose Solorio's Avatar
I'm having g the same problem with my speedometer. Any luck finding a solution?
Lukelis
Oct 18, 2017 11:42 AM
zink_karma
Lancer Aftermarket Forced Induction Tech
Oct 17, 2016 06:03 PM
jdrames
Lancer Troubleshooting
Jun 3, 2016 02:38 PM
garditox
04-06 Lancer Ralliart How To Requests / Questions / Tips
13
Jul 30, 2010 02:21 AM
b18flip
13
Nov 21, 2003 10:09 PM
